14 bolt FF disc brake problem...
Discussion in 'The Garage' started by divorced, Oct 13, 2004.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I put disc brakes on my 14 bolt and now have a small problem. After driving for a couple of miles they will start to make a noise, it is difficult to describe but while driving fast it sounds similar to the noise a mud tire makes while driving. While going very slow the noise sounds like when the brakes make a "groan" noise if you are stopped and release just enough pressure to roll a bit, and I can tell that it only makes this noise on a small part of the rotor, the noise gets loud then quiet then loud then... I used new brake hoses, rotors, and calipers and they aren't sticking. When I installed the new rotors the lug studs fit loose in the rotor holes but tight in the hub holes, so I know that the rotors aren't centered. The noise to me seems like a warped rotor. Do the rotors usually need turned before installing the hub/rotor on the truck?
  2. 409demon
    409demon Registered Member
    Oct 9, 2004
    19
    does any one have the measurments on how to make brackets and what year caliper and rotor, does any year 73-83 3/4 ton parts work?
  3. divorced
    Jul 20, 2004
    5,115
    I don't have any measurements, I bought my brackets from cybrfire. I used calipers from a 1979 K20 so that they would match the front.
  4. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    DIY makes some that are a really good price. I got mine from Sky-Manufacturing because they wer bent the correct way and did not use the stand out spacers. I used the Caliper and rotors off of a 78 K20. Half ton and 3/4 ton Calipers are the same and will bolt right up. I used the Az-Kickin off road supply brake line kit. /forums/images/graemlins/waytogo.gif
  5. divorced
    Jul 20, 2004
    5,115
    The DIY brackets use solid steel discs for the spacers, and in my opinion are superior to the other kits that use pieces of pipe. The bent brackets look nice also.
  6. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    A new rotor shouldn't require turning. You may want to pull it back apart and look at your pads. I have had them make a similar noise and the only thing wrong with them is they got diff fluid on them in the installation process. Other than that not sure what to tell you. Stud holes should have fit damn close and snug on the rotor.
  7. divorced
    Jul 20, 2004
    5,115
    Ok, I'll check it out. It's back in the garage now for a while for other repairs/modifications anyway.
  8. 409demon
    Oct 9, 2004
    19
    does any one have the diamiter of the rotors used and inside width where the caliper goes between the braket?
  9. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Any rust between rotor and the assembly that it compresses against?
    It sounds like (even though they are new) the brake lines may have internally collapsed.
    Maybe a damaged hub causing the rotor to wobble as it turns?
    Good luck /forums/images/graemlins/thumb.gif
