14-bolt FF dually info
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RodeoRob, Nov 27, 2001.
  1. RodeoRob
    RodeoRob Registered Member
    Sep 16, 2001
    17
    Winston-Salem, NC, USA
    hey, was wondering if you guys can provide an outsider with some info. I ran across a Jeeper running a 14bff dually on his Jeep, of course with single wheels, because its only 62" wide in this configuration... perfect for those non-fullsize rigs.
    I was looking at a D60 FF and cutting it down to length with custom shafts... but i like the idea of something i wouldn't have to touch and being able to stick with 'standard' shafts.
    Now, i'm familar with the 14bff, helped blazin86 install his... but not familar with the dually axles. what, if any, modifications am i looking at to run a dually axle with single wheels? Also, what models and years can i find the 14bff dually axle? they came off 1.5 tons right? what years?
    -Rob
    1995.5 Isuzu Rodeo
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    They came off of 1 ton trucks 73-97. All you need to do is buy a different wheel thats ment for a single wheel axle (any 8 lug wheel as long as its not meant for a dually).
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I can't verify any dimensions...but the 14 FF dually axle was used in two wheel and 4 wheel drive trucks as well as cab and chassis models. You should be able to snag one almost free...[​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I believe what you are looking for is an axle from a cab-and-chassis. Pickup dually rears are wider than single wheel axles, but the cab-and-chassis rears are (at least in manny cases, if not all) narrower. I have also seen a box Bronco running a dually 70 rear (perhaps from a brand F or D?) that was fairly narrow. Bottom line, with something like this, look before you buy.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    A dually rearend is the same width as a regular 1t. Spring perches are 1" narrower than 1/2t &amp; 3/4t's.
    1 ton '87 Chevy SWB in the making!
