14 bolt FF from an '80 chevy van
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NOT4SHW, Jun 9, 2001.
  1. NOT4SHW
    NOT4SHW Guest
    14 bolt FF from an \'80 chevy van
    Does anyone know if a 14 bolt FF from a '80 van will fit my '79 k5? I found one for a killer price and I was wondering if anyone had made the swap before?
    '79 K5,13 1/2" lift, 39.5 TSL's,15x12 Eagles,350,t-350,warn 8274,
  2. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Re: 14 bolt FF from an \'80 chevy van
    Just measure up the spring perches... Either way if it doesn't bolt right on it isn't hard to make it fit, I remember hearing something about van axles being wider also, might want ot check into that also even though it won't make a difference in making it work. Keep us posted.
    Mike
    You call that dirty!?
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I think the van rears are wider then the truck rears by a few inches.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails<font color=blue>
    <font color=blue>Wayne<font color=blue>
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The van rears are the same width (or real close to it) as the front axles (69") as oposed to truck rears which are all 67". All you need to do is torch off the old spring pads and shock mounts and weld your own on.</font color=blue>
    [image]http://bbs.off-road.com/wwwthreads_uploads/53-288682-mudpit3.jpg[/image]
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If they are wider this could be a cure for the rear being narower than the front. Something I'll have to look into because I didn't know they were wider.
    '71 Blazer CST with alot of rust
