14 Bolt FF GovLoc Limited Slips?
Discussion in 'The Garage' started by Fry, Jun 4, 2004.
  1. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    My 14 bolt has a Gov Loc in it but isn't making too great of noises and is not very smooth when transferring power between wheels. So before it piles up, which it will I'm sure I want to replace it with another Limited Slip. Can't go full locker due to ice driving, had one in my old camaro, trust me ice and lockers don't mix. What options do I have? I have read a little on rebuilding the eaton and something about a powertrax for the govloc diffs.
    Any insight would be appreciated.
    /forums/images/graemlins/thumb.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A Powertrax is still a locker.
    If you're heart set on a limited slip Eaton makes a posi for the 14 bolt I do believe.
    If it were me I'd detroit it.
  3. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    you probably never drove a locker on an icey road either though.
  4. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    You can get a rebuild kit(clutch plates and such) from the dealer. Doesn't look like it would be that hard of a rebuild. If you don't want to rebuild it Power Trax No-slip would be a good option more of a true locker but supose to still slip when full lock is not needed.
  5. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
  6. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    ED-19689-010 GM 10.5, 4.10:1 and Down
    Part Number Standard Package Required
    per Unit
    96535-00S Guide - Left Hand Disc Pack12 pieces6 pieces
    89140-00S Guide - Right Hand Disc Pack12 pieces6 pieces
    29255-00S Preload System Service Kit - 400#1 spring, 2 preload spring thrust sleeves1 set
    096744-100 Flat Head Machine Screw12 pieces3 pieces
    29254-00S Gear Service Kit2 side gears,
    3 pinion gears
    1 gear thrust sleeve1 set
    29252-00S Disc Service Kit - Right Hand (Carbon)9 discs, 6 guides1 set
    29253-00S Disc Service Kit - Left Hand (Carbon)4 discs, 6 guides1 set
    99311-00S Pinion Thrust Washer10 pieces3 pieces
    89179-00S Pinion Yoke11
    29256-00S Shim Kit20 each of 8 sizes2 shims
    This is what I've found on Eatons site, should do it if I don't really have any other cheaper options. I would consider a "no-slip" diff like the one offered by powertrax but haven't found anything for a stock gov loc diff.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My daily driver is locked in the rear and has a 108" wheelbase. I like it much better than an open diff, I feel that you have much more control.
  8. Jays Beast
    Aug 7, 2002
    538
    Chandler, AZ
    /forums/images/graemlins/dunno.gif when I call central4wd.com the guy I talked with said that power-trax made a no-slip for the 14bff gov-lock. /forums/images/graemlins/thinking.gif I will have to do some more checking cause that is what I was going to order when I had saved up the money. If you rebuild yours post up how hard it was and if you notice improvement. May rebuild or weld mine if can't find a no-slip.
  9. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    Thats funny, I found that a locker with winter tires would only slide sideways off the line. So much so that I was actually stuck at an intersection waiting for the cars by the side of me to go through before I could go because I took up 2 lanes. Now correct me if I'm wrong but yours is a shortbox with swampers, that would do nothing but slide sideways on ice, I've never been to Il but you must not get very much ice, or your roads are salted & sanded heavily.
  10. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    The roads do ice occasionaly here, but nothing like where you live. If it does ice, usually there are enough patches of pavement to get traction on. The ice never lasts more than a day, the state sprays de-icer and salt on the roads pretty heavily.
  11. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    you guys are lucky then, where I just moved from (4 hrs from here) they didn't plow the roads for most of the winter so it would build up then turn to ice and you can't get rid of it till spring. Didn't help that they were scared to salt the roads. Hope this new place gets rid of ice quicker.
  12. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Just an fyi, a Govlock is a true locker. A Powertrax no spin acts just like a Detroit. With the conditions you have to drive in I would just stick with the Govlock. Look around in junkyards because they are easy to find for 14ff's and it should be a lot cheaper then a rebuild.
  13. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Sorry, i have to disagree with that last statement, i have a Gov-Loc in the rear of mine, and slips all the time, it will however lock up when wheelspin on one side starts up, then it grabs pretty good, but DEFINATELY NOT locked all the time.
    I believe they are more like a tight limited slip.
    Not the normal limited slip like cars have, but something "tighter" kinda hard to explain what i'm saying though.
  14. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    So you would consider an ARB selectable locker as not a true locker because it isn't engaged all the time? A gov lock is like a selectable locker. It is not like a limited slip. A limited slip has the clutches engaged all the time but allows slippage between them when going around a turn. A gov lock acts as a selectable locker. Open for normal driving, but when it has to engage it locks solid with no slippage. The definition of a locker is a device that is designed so when engaged it locks the 2 rear axles together. A properly functioning gov loc does this.
  15. 4xcrazy
    Oct 31, 2003
    9,471
    5
    No they do not lock solid without slippage, i just mentioned this, they do still slip. And a Gov-Loc does use clutches in it as well.
    They lock to a certain degree, then will slip if the pressure is too great, this is why i want to go with a Detroit in hopse of a more "locked" rear diff.
    Just talk with the people who have wheeled with me and have seen my rear diff work,,,,or not work right as it is.
    Now i have seen the 10 bolt Gov-Loc work in a friends truck, that one did seem to lock tighter when the hil climbs were on, maybe because it's a different setup then the 14b, i dunno, but all i know i guess is mine does not work as you are decsribing, it does help but does not lock like you are saying.
  16. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    A gov-loc doesn't have a mechanical locking device inside of it like an ARB, Lockrite, PowerTrax, Detroit, etc. None of those use clutches. They use mechanical engagement of metal teeth to lock. However, when a gov-loc is new it will grab very tightly when engaged, but not like a solid mechanical locker. The bummer is that as the clutches wear, the grip slowly fades away. Rebuilding one is pretty easy, but GM gets over $150 for the clutches. /forums/images/graemlins/eek.gif
  17. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Your right they are not locked all the time and neither is a Detroit. They are considered a true locker though. They have clutches to engage them which requires wheel spin to lock and they unlock once you don't have power to it. They are also supposed to unlock at 25 or so mph. If yours slips then the clutches are toasted because they are not supposed to slip.
  18. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    A Detroit Locker is locked about 99.9% of the time. The only time it unlocks is when one axle is trying to spin faster than the diff case (as in when turning a corner). The rest of the time both axles are locked solidly together.
    And unlike a Gov-Loc, there is no true differentiation with a Detroit (or Lockrite, Powertrax, etc.) The way that it allows one axle to go faster than the diff case is to completely disconnect it from the drivetrain. /forums/images/graemlins/eek.gif It doesn't have any spider gears at all so you get either all or nothing...
