14 bolt FF hub installation?
Discussion in 'The Garage' started by Kingston, Jul 28, 2005.
  1. Kingston
    Kingston Registered Member
    Aug 1, 2001
    7
    Alberta, Canada
    Which order do I put these back on the spindle. I think its this way or Am I wrong?
    1st - Spindle nut (inner spindle collar)
    2nd - Spindle flat washer,
    3rd - Spindle lock-washer
    4th - spindle lock nut (outer spindle collar)
    Is this correct or does the spindle flat washer go first and then the inner spindle collar. also I lost one off the spindle flat washers, can I get away with out it or must I use it.
  2. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    if i am correct its flat washer/inner nut/then torque to spec 50ftlb/lockwasher/outer nut/torque to spec?
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    should be:
    washer
    nut
    locking cage thing
    nut
  4. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Mine didn't have the cage thing that I keep hearing about. I've got a locking key that slides into slots in the nut and spindle and a snap ring that holds it in place. Is this a Military thing?
