14 bolt FF hubs with disc brakes studs
Discussion in 'The Garage' started by mostwanted, Mar 9, 2007.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    I am just curious which studs to use with a 14bolt hub and a GM 3/4ton rotor.
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i used the ones i drove out. just press or beat them back in w/ the rotor
  3. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    i had to buy some for a dually 14 bolt cause i had alumiumn wheels
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    As long as your 14ff had the 13" drums then you will re-use the original studs. One thing that i've found out though is that some (most) of the 3/4 ton rotors the machined area for the stud head to sit in is too small and the best method is to machine the head of the stud so it is 1" in diameter. Doing this will allow you to never have to deal with it again. The other option is the machine the stud recess in the rotor larger but then if you ever need another rotor you may have to do it again to the new rotor.
  5. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    X2.
    Sixty two dollars worth.
