14 bolt FF locker suggestions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, May 18, 2001.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Need a locker for my FF...Seems like there arent too many choices out there. Not too crazy about clanging and banging of a detroit....whats my options?
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5 [​IMG]
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    For a locker you have 2 choices (that I know about). Detroit Locker, or Lincoln Locker (weld up). Several guys are running LLs and like them allot. No popping or clanging and they are 100% predictable. Only down side is chirping in parking lots and of course, a tendency to "push" through.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  3. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    I don't think the detroit "clanks or bangs" much. In fact, once you get used to driving with a detroit, you'll forget it's back there. I have been driving with one for over 4 years with not one problem, ever out of the locker. I bet if you asked, most people with a detroit would agree that it's not that bad at all to drive on the street.
    BIGJ
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Had my detroit in the 14 bolt goin on 3 years now. I love it. On the street its hardly noticable and certainly doesnt warrant welding on the gears to achieve a worse effect on the street.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    1. Eaton Gov-Lock
    2. Detroit Locker
    3. Lock Right (3 pin and 4 pin available)
    4. Lincoln Locker
    When In Doubt, Whip It Out!
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Cool, I thought a while back that there was a Lock Right for it, but then I had several people told me that there wasn't. Cool.
    Is the C14FF Gov-Lock better than the C10 versions? I know most people say to stay away from them but maybe that doesn't apply to the C14FF?
    I'm also of the opinion that there is no problem with driving the DL on the street, you just have to get used to it and learn how it will react differently. Rene (tRusty) and several others are running welded diffs in daily drivers and really like them. I don’t know, never tried that one.
    Bad Dog
  7. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Check out detroits new style locker for the 14ff it is not supposed to have any feel when it activates and little or no clunking. Call around or call them about it.
    Brent
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    My 85 K30 has the Gov-Lock in it. It works very well as long as the posi-lube is in it. When I turn corners, the tires sometimes chirp and grab. True signs that its working! [​IMG]
    Rene was just here at my place tonight. We talked about his welded locker. Seems to hold up good since he is doing a 4800 mile round trip to get another blazer. Very cool guy, too!
  9. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    Why not use an ARB?
    "K5 Grand GT Blazer Silverado in the Netherlands."
  10. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    My vote is for the detroit. They are reasonably priced for the 14ff and my truck makes enuff other road noise I don't even notice its there.(till I hit the trails)
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    ARB does not make the Air Locker for this axle. [​IMG]
  12. Sammy
    Dec 8, 2000
    250
    Strange that I have a ARB airlocker on my bench, that came out of a 14bolt FF.
  13. Cavalry
    Oct 1, 2000
    978
    I had a detroit in my 5.0 disgustang, thought it clanged and banged quite a bit. I currently have a gov-lock in my 10 bolt and it has accectable amounts of noise...did I just have a loud detroit? Any one running the new eatons?
    Luke
    84 K5 [​IMG]
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    Are you sure its the FF? I think I read somewhere on a site that ARB makes the Air Locker for the SF rear, not the FF.
  15. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    yea, I kinda thought I had seen arb's for the FF, but I checked into it and they don't make one! bummer [​IMG]
    <font color=blue> Jeff </font color=blue>
    [​IMG][​IMG]
  16. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    ARB for the 14FF should be out in a year or two when I last got a note from ARB. (that was months ago)
    Would like to see if Trachtech (truetrac) come out with the electronically activated lockers. It's a truetrac LSD normally and a full locker when activated. This would be a great product.
    <font color=green>Joe Angelicchio
    86 Jimmy 4+3, 35-&gt;39.5 tires,4spd
    </font color=green>
    [​IMG][​IMG]
    <P ID="edit"><FONT SIZE=-1>Edited by JoeAngelicchio on 05/19/01 08:20 PM (server time).</FONT></P>
  17. 85k5blzr
    85k5blzr 1/2 ton status
    Jan 10, 2001
    103
    Houston, Texas
    It will probably be as much as the ARB, but with the ARB you get all mechanical, no electrical, and an air compressor [​IMG].
    K5 just upgraded to rig status! [​IMG]
  18. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I thought most 14bolts FF came with Eaton "No-Spin" which is about the same thing in operation as a Detroit Locker. Someone must have the staight scoop on this. Never heard or saw a 14bolt with a Gov-Lok, only 10bolts.
