14 bolt FF question .
Discussion in 'The Garage' started by Z3PR, Oct 4, 2002.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I hope this doesn't sound ignorent. Is there any difference in the 14 bolt FF from a 3/4 ton vers one from a 1 ton ???? Or are they the same ??? /forums/images/graemlins/k5.gif
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Spring pad distance and brake size
  3. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Shock location is different too.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    ( brake size ) Can that be upgraded to 1 ton ??? What all would be involved ???
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    if you are worried about upgrading anything it should be to disk brakes.not bigger heavier drums. /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    How hard is that conversion ??? What ALL would I NEED ???
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Backing plates, drums, and shoes. Make sure the backing plates use the same style of parking brake - one has a triangle hole w/two bolts, the other round.
  8. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    I got my disc brake brackets from DERBINATOR for 100 bucks, then went to Autozone to get the rotors, calipers, and brake pads for another 75 bucks. EASY install, nothing to it. Looks sweet (pics of mine in my member's gallery), and you save about 150 pounds of weight. /forums/images/graemlins/thumb.gif
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Post a link for your webshots please
  10. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Thank you. It looks like a fairly simple conversion. Does it give you anymore stopping power ??? Would a dual caliper set-up be possible ??? I'm thinking dual pistons in each caliper, and duel calipers per rotor. I want to build some major stopping power.
  12. or2play
    Feb 22, 2002
    657
    Yuma, Arizona
    I noticed increased stopping power on the first test drive. Ideally the best thing to do would be replace the master cylinder and proportioning valve with parts that were intended to be used in a 4 wheel disc system. Then again there's always that hydroboost conversion.....
