14 bolt ff rear disc brakes, options???What works and lasts,what doesnt
Discussion in 'The Garage' started by camiswelding, Jul 16, 2003.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    Off road unlimited sells a complete kit but its nearly twice what all the other "get the parts yourself" kits out there. Does anyone have any experience with this and is there a reason why other than "they can" charge that much?
    heres their kit (UNDER PARTS SECTION) http://www.offroadunlimited.com/new/custom/custom_inside_index.html
    Its close to 1400 buckos....and I am unsure if their kits uses caddy calipers... from what I glean other kits can be made for less than half of that with minimal parts searching effort
    can the caddy calipers stand up to the truck use..
    is the caddy ebrake reliable? blazers are heavier than caddies by 1-2k pounds I would say and no one seems to fully address this question in their sites
    cam
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I used azkickin's kit and it's great /forums/images/graemlins/thumb.gif. I used GM rotors and calipers. Rotors-$25 each Calipers-$15 each Pads-$12. Azkickin also sells the optional hose kit...that I highly recommend (instead of trying to piece your own together)
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    we used az-kickins on chevy4wds, just the brackets, hoses and bolts, used 3/4 ton front rotors and 3/4 ton front calipers...works GREAT
  5. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    Az kickin it will be then... They were nice enough to write me directly from this post and tell me about their kit... Im waiting for Harry3 to give us an update on the ebrake proto kit they made for him. Its nice to support K5 friendly companies
    cam
    HOW MANY OF YOU NEEDED PROPOTIONING VALVES TO MAKE IT WORK?
