14 bolt ff rear into 72
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by aero, Feb 7, 2002.
  1. aero
    aero Newbie
    Feb 7, 2002
    Does anyone know of a 14 bolt ff rearend that would bolt into a 72 k5 blazer? I am curious if one exists with the same spring pad width as my 72. If so, is the overall width comparable?
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    yes, i belive that the ones from 1 tons will bolt right up. 3/4 ones will bolt into the 73+ blazers. BTW 3/4 and 1 ton 14FF are identical except for the brakes size and spring pad width. the chevy vans have a wider 14ff, about 3"
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>One ton 14 bolts have the correct spring pad spacing. The shock mounts will have to be relocated and you may or may not need degree shims for the pinion angle.
