14 bolt FF Rear question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SmokinLB7, Mar 24, 2007.
  1. SmokinLB7
    SmokinLB7 1/2 ton status
    Mar 21, 2007
    118
    Greeley, CO
    I am looking at a 14 bolt full floater rear axle and it came off of a 78 or so dually. I have a few questions?
    Is there going to be an issue with making it a single rear wheel?
    I was told that it is shorter than the regular 14 bolt rear, what is that going to do for clearance of the rear tires and articulation?
    Also, are the spring perches going to be the same width or are they differant?
    I am really looking for help quick on this one, and any help is appreciated. Thank you very much in advance.
    Zach
  2. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    I think the cab and chassis axles are narrower, not sure about the K30/C30 dually axles though.
  3. SmokinLB7
    Mar 21, 2007
    118
    Greeley, CO
    Thanks for your SPEEEEEED! It was a chassis cab dually. If that helps. So is it going to affect anything?
  4. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    1 ton spring perches are different, it would need new perches welded on.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If it a CC 14bff it's going to be tough to relocate the perches since the spring as it is is too close to the drum, putting the springs further out will probably not work.
    Unfortunately I don't have it any more so i can't confirm the numbers, but when i was pulling it off, it was very tight and couldn't get a lot of movement with the wrenches:confused:
  6. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    If you throw this in thread in the garage, it has a ton more traffic and you will get more help.
