14 Bolt FF Slop
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by okie k5, Jun 13, 2004.
  1. okie k5
    okie k5 Registered Member
    Oct 27, 2003
    74
    Moore, OK
    I 've got a 14 Bolt FF and the pinion yoke has some hellacious rotational slop. I would estimate that the yoke rotates roughly 45 or 50 degrees before actually engaging the ring gear. Is this normal? I don't think it is and I was planning on having a shop check it out. What are some likely causes and what kind of prices are we talking about. I realize labor rates vary, I just don't want to get rouchambeaued.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Definilty not normal and needs checked out
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If it has a Detroit Locker and 4.56 gears, then that would be normal. /forums/images/graemlins/yikes.gif
    To read why, click on the link in my sig, then select "Tech Articles", then the link for locking differentials. /forums/images/graemlins/cool.gif
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    With a detroit the 14FF can allow a lot of slop. My rig rolls about 2 feet sometimes due to this slop (rolls when parked on incline). I have asked a few owners of this set up and they all said it was normal.
  5. fwdjunky
    fwdjunky 1/2 ton status
    Oct 12, 2003
    499
    Maricopa, AZ
    Great article! Makes me rethink my thoery that my spud shaft is worn, maybe all that slop is due to a detroit and 4.10's. Nah, I couldn't get that lucky.
  6. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    NO, for soem reason theres always more movement at the yoke then the ring gear. If you dont have a locker then thats not right. You could always pull the cover and check it out though.
  8. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I had the same problem with my 14ff when I picked it up from the wrecking yard. Lots of slop and I just had a govlok and 4.10's. When I first got it going the R7p were howling like crazy so I took it to a gear shop and they popped in new pinion bearings which were coming apart letting the pinion slide in too far.
  9. okie k5
    Oct 27, 2003
    74
    Moore, OK
    A gear shop told me it is normal for the 14 Bolt. The killer is that it wore out a Dana/Spicer ujoint in 12,000 miles. That is awful quick as far as I am concerned. If I have to replace ujoints every 12,000 miles I can live with that, but if it is not normal I don't want to. Thanks for the posts and the answers.
