14 Bolt ff spool
Discussion in 'The Garage' started by k5blazerus, Nov 20, 2002.
  1. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I just saw a picture of a spool for a 14 bolt ff in the knew fourwheeler mag.$170 Is it worth it. I know it will stay locked in the rear at all time's but when I had my detroit in the rear of my 1/2 in my blazer it chirped the tires all the time and it seemed to act like a spool.
    So would it be worth it? or should I get the detroit for my 14 bolt.
    Colin
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Don't bother with the spool, if you want it permanently locked then just weld that puppy up. The 14 bolt has the beef in the spiders to take being welded and will hold up just fine. Here's a pic of my welded 14 bolt spiders before I de-boogered them.
    [​IMG] </font color>
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    $167.95 for the spool shown in the magazine. I think I would rather pay this rather than weld something and worry that the welds could/may fail in the future. No matter how good a welder someone is. But this is just me. (And my money, too! /forums/images/graemlins/grin.gif)
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green">That's understandable, but theres an awful lot of surface area to weld on 14 bolt spiders. I think I'd spend the extra $100 and get a Detroit over the spool if I were to actually spend money on it. </font color>
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    If I were doing the rock crawling scene and had a truck that was purely a crawler, then I would go with the spool.
    But for something I need to drive more on the streets and still want to have a locker in the rear for, I would get the Detroit for it. /forums/images/graemlins/thumb.gif
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    just weld it and don't bother with a spool. I did. I don't mind it that much, and it is my daily driver. I might go and get a detroit if I get the $ but the welded is great.
  7. k5blazerus
    Apr 22, 2001
    654
    Bend, OR
    If I was in the rockcrawler seen I would to weld the rear or put a spool in. But for $170 and your locked in the rear. I drive my truck daily on the road and take it out on the weekend's to go play in the mud,sand,snow. So mybe I should lock the rear up right and get the detroit.
    Colin
  8. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    You know---i thought i was the only one that thought this way----i have mine welded right now and am definately thinking about that spool---i think it is worth it in the peice of mind aspect
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I welded mine up. If I ever change it I will go with a Detroit for 2 reasons:
    1) Sharper turning radius on pavement
    2) I could twin stick my 205 and use turning breaks.
  10. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Was looking for another 14B spider weld post.Other said to weld 1 skip 1 weld 1 skip 2 weld 1 skip 1 weld 1 skip 2.This method doesn't weld gears together and doesn't ruin carrier.Had pic of spiders with weld. /forums/images/graemlins/thumb.gif
  11. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
  12. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    OK Shaggy, this may seem kinda basic, but how exactly did you get everything lined up properly to weld it up. Did you just stack it up on the bench and start smokin it, or did you tack it all together in the carrier, THEN take it out to finish? It almost looks like the cross inside would just about line it all up and make the side gears flush to the spiders.
    I am looking into doing my rear very soon, as in the next few weeks. I have never opened up my 14 so I dont know what exactly is going on in there. /forums/images/graemlins/crazy.gif Ive looked at pics and read the article, but would rather weld it up solid. /forums/images/graemlins/1zhelp.gif
    And finally, will a Detroit still go in later if I wanted to?
  13. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    lol, I welded Shaggy's stuff. The spiders are welded to the side gears and the spiders to the cross shaft. Just tacked it all together in the carrier then pulled it out and welded it up. Gotta make sure the tacks are good ones though. Don't want the heat to pull anything out of aligment when ya start welding it up. The insides of a 14 bolt are waaay simple. When I welded mine, it took me about 2 hours from the time I pulled the first cover bolt till the time I torqued the last one. And yes you could pull out the welded spiders and drop in a Detriot no problem. Nothing about the carrier is changed. I think that if i were to swap a Detriot in mine I could do it in less than an hour. If ya want, send me your carrier minus the ring gear with the spiders, side gears, and cross shaft, I'll weld it up like Shaggy's, then send it back to ya. Did the same for Shaggy. I think the shipping might kill it though.
  14. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    $170 isnt worth it IMO... just weld the spider gears (like the tech article on ck5 says) and then spend a lil cash (ie, WAY less than $170) to get an extra set of spiders. If you EVER want your axle "unwelded" or to put a detroit in or whatever, u just swap in that extra set of spiders you have and presto, you're set. /forums/images/graemlins/smile.gif
    j
  15. 88jimmyoungowner
    88jimmyoungowner 1/2 ton status
    Nov 20, 2001
    425
    georgia-rome
    question: where can i order it?
    do spools replace the carrier, or am i wrong? i think if the spool replaces the ebtire carrier, then i will go ahead and buy my gears and the spool and do them at the same time. thanks.
  16. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    OK so what should I do, lay in the side gear, stack the spiders and cross in there and tack it, then take it out and lay in the other side gear and stack on the already tacked assembly and tack it up. Then remove the whole thing and smoke it together on the bench.
    Ill be useing a 110v mig on max boost. (and using the pic above as a reference)
  17. ZonkRat
    Jan 16, 2003
    1,003
    Had Detroit few years ago_Old model with 16 spline axles.Couldn't get parts.Welded now.Prefer weld cause it acts same all the time.Locker shock loads axles worse and will over --under steer depending on throttle aplication. /forums/images/graemlins/thumb.gif
  18. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i am going to have somebody weld mine up. then im going to run 1 wheel drive in the back. i have 3 "stub" axles for a 14 bolt FF. they are axles chopped off about 2 inches after the flange.
    it doesnt take long to change out a shaft on the dang things.
    the second option is to see if the truck i pulled the D60 off of has a detroit. then ill just swap that right in. BUT to me the cheaper the better.... so long as it is safe.
    grant
  19. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    good point
  20. ZonkRat
    Jan 16, 2003
    1,003
    Had one wheel drive when detroit broke.Makes for some strange handling.I'd take drivers side axle out,Make it pull toward shoulder instead of oncoming traffic. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
