14 bolt ff swap??
Discussion in 'The Garage' started by 85mudblazin, May 9, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I have 10 bolts front and rear and I want to swap out the rear for a 14 bolt ff and I was wondering what all has to be done to complete the swap. Thanks /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    unbolt the 10b. remove. put the 14bff in. bolt up. /forums/images/graemlins/dunno.gif
  3. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    umm... dammit, I swore there was a tech article on this.
    Consider a few things... van or dually 14 bolts have different spring perch widths, so be sure to get a 3/4 ton (or 1 ton SRW?) 14 bolt.
    You'll need to do something creative for the driveshaft -- a combo Uijoint, I think.
    Also consider that the 14 bolt will be 8 lug and your front will be 6. You could carry two spares, or none... or switch the front to 8 lug, same parts as a D44, IIRC. Adapters are available but aren't cheap -- prolly cheaper to convert the front over.
    -- A
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Hours of back breaking labor /forums/images/graemlins/thumb.gif Seriously it is basically just remove old one put new one on, you will have to buy a ujoint to fit your 1/2 ton driveshaft and the 3/4 ton yoke on the 14ff. Also the e brake lines will have to be altered a little on a newer rig i believe it's 81's and up /forums/images/graemlins/thinking.gif If you do it then let me know and I can help you with the e brake riggin'. I think I have some pic's in the pc somewhere /forums/images/graemlins/whistling.gif
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Thanks but one more question, what do you do with the brakes should I try and find a 14 bolt with good brakes or is there some way to put the drums on there from the 10 bolt? Thanks /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  6. dremu
    Feb 27, 2000
    15,954
    445
    No 10 bolt parts will fit -- the drums on the 14 bolts are approximately the size of Rhode Island. /forums/images/graemlins/thumb.gif
    If you get one with crappy brakes, consider doing a disc conversion. Or just fixing the brakes -- have the drums turned, new shoes, maybe replace the wheel cylinders if they look squishy... not bad.
    -- A
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I kept the drums that were on the 14ff and will upgrade to disk in the future. the bake lines match right up to the 14ff from the 10 bolt. The e brake setup is what will need to change /forums/images/graemlins/deal.gif
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    what are some things to look for when shopping the junkyard for a 14 bolt??
  9. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Tech Article: HERE
    Its amazing how much good info is available if you select "Technical" in the scroll down Navigation menu at the top of the page. Not only should search be used, but perhaps the pages and pages of info also available here on the site /forums/images/graemlins/deal.gif /forums/images/graemlins/rotfl.gif
  10. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    not to hyjack
    how can you tell if it has a gov-lock?
    thanks
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I dont really want to have to buy new rims so would a 14 bolt sf be a better choice and is it strong?
  12. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I have a 14sf it's 8 lug. I think the newer one 92' and up are in 6 lug not really sure though.
  13. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    It will look like this when you take the cover off
  14. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ] Just do a brake job if they are worn out. Also there is the option to do a disc brake conversion that is realitivly easy.
    [/ QUOTE ]Look for a PAIR of axles out of a K20 with preferably 4.56 gears. Don't be afraid of a 14BFF gov-lok, it won't break on you and the worse case scenerio is it doesn't work all that well from many miles of use but chances are it will keep both tires spinning better than an open version would.
    As far as the E-brake goes, if you get a set of axles out of an 81' and later model than it will bolt up to your 85'K5 linkage. Earlier axles are a bit different, I still havent hooked mine up because of this reason.
  15. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Buy some cheapo 15" 8 lug rims for the time being. i was lucky to get a good set of rims when I did my axle swap. i also bought new tires before swapping over so I could get 16" tires.
  16. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
  17. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Forget the SF14B IMHO, you probably already have too high of gears with your 10B's and you would still have to use the old high geared front. Get a set of 8 lug axles because the 14BFF is way better than the SF14, lower gears, and the front 3/4 version 10B/D44 has 8 lug hubs and would be very easy to then just swap in a D60 down the road if you choose to go hardcore one day. Sell your rims(unless you have some that are expensive like Welds, then I would reconsider) and just get some new 8 lugger 15 or 16 inchers. /forums/images/graemlins/waytogo.gif
  18. dremu
    Feb 27, 2000
    15,954
    445
    dammit, I *knew* I missed it...
    -- A
  19. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Also note the small hole on the left lower side by the ring gear. An open diff has 4 holes ( one for each spider gear) and the gov-lok only has three. Oh, and they are not holes per-say, but thats what it kinda looks like in the pic /forums/images/graemlins/thumb.gif
