14 Bolt FF swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by headcrash0101, Dec 9, 2003.
  1. headcrash0101
    headcrash0101 Registered Member
    Nov 4, 2003
    17
    Can anyone tell me what is involved in swapping a 14B FF into my 87 Blazer. Does it matter if it's out of a 2WD or a 4WD. What is the stock pinion angle for an 87 Blazer. With a 6 lift give or take what degree shim should I use front and rear?
  2. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Larger u-bolts and a conversion u-joint.
  3. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    You may have to change the shock mounts and spring perches depending on what you pulled it out of.
    You won't have ot use shims up front, and depends what you're doing for the rear you may not need shims. Make sure to lower the t-case you may need a longer shaft.
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    2WD 4WD doesn't really matter shock mounts hang lower on the 2WD is the only bad thing. If it is from a 3/4 ton it will bolt right up if it's from a 1 ton the shock mounts and spring perches have to be moved 1 Ton's are narrower I believe /forums/images/graemlins/thumb.gif
