14 Bolt Ff ?
Discussion in 'The Garage' started by 88burb, Dec 11, 2004.
  1. 88burb
    88burb Registered Member
    Nov 15, 2004
    33
    How Do I Get These Huge Drums Off Do I Need To Take Out All The Bolts On The Hubs Thats The Only Way I See Them Coming Off?????
    Thanks Lance
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yep, you have to unbolt the axle shafts and pull the spindle nuts to get the drum/hub assembly off.
  3. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Yep; take off the capitalization of the first letter of every word ... err, take off the hub bolts, pull the shafts out.
    Break out the magic six-sided socket, or use a screwdriver (no no no, use the socket :) Might have to remove a snap ring to unlock the nuts.
    Remove the nuts -- much like the front axle in this regard -- and then the drum, hub, and bearings all come off. They Are Freaking Heavy (ack, no I'm doing it :)
    The joy -- and the PITA -- of full-floating is that the bearings are outboard.
    -- A
