14 BOLT FF
Discussion in 'The Garage' started by CHEVY 4WD, Dec 27, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Well I have a bad 10bolt(the housing is actually BENT) I have been looking for a 12 bolt for a wile now or even 10 bolts but haven’t really found much and if I get a 10/12 bolt its gotta have 3.73's or lower which seems to be pretty rare. After looking around the classifys here I sal some 14bolts with 3.73's or 4.10's for like $150 and it seems to be kinnda make me want one of those (always been against the weight) ANYWAYS what im asking is is there a difference in the 14bolts? I no there’s a SF and FF but are 3/4 and 1 ton the same and are the 2wd's the same?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The 3/4 and 1 ton have the spring perches in a slightly different location. You want the 3/4 ton version. Not sure about the 2 wheel drive version but somebody here will.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Other than the spring perch locations between the 3/4 and 1 tons, the other differences between a 2wd and 4wd version of the 3/4 ton 14FF are the shock mounts.
    2wd mounts sit lower than the 4wd mounts. Around 3" lower or so.
    Should not matter which you find. Either will work just fine. Just have to watch out for which one you find and get the proper length of shocks. /forums/images/graemlins/wink.gif
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Or cut and re-weld your shock mounts higher up like I did. /forums/images/graemlins/thumb.gif
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, you could do that...but I prefer to use the longer mounts, if it is the 2wd rear.
    Reason to use the longer 2wd mounts is the same as using the Ford shock towers up front...to gain longer travel shockes. Having that extra 3" will allow you to use a longer shock as you would install those with the Ford towers. /forums/images/graemlins/wink.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    But if you play in the rocks those mounts just become 2 additional anchors to get hung on. /forums/images/graemlins/frown.gif
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I'm doing that change over right now and made a set of spring perches and shock mount that I'll be welding on, the 14FF has an open diff that you can drop a locker in for about $325.00, check out my link to see all the work I'm doing on it...
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, a big if to that answer! /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
