14 bolt ff
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cinchjeancowboy, Dec 7, 2003.
  1. cinchjeancowboy
    cinchjeancowboy Registered Member
    Dec 7, 2003
    10
    North East Texas
    What all is needed or has to be done to add a 14 bolt FF to my 1/2 suburban??Some one told Me I had to move the pads?? I am buying front and rear axles out of a 3/4 ton 4x4..
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Your truck and what you said you're buying...direct swap. Spring pads only need to be moved on the rear axle if it's taken from a 1 ton truck. /forums/images/graemlins/thumb.gif
  3. cinchjeancowboy
    Dec 7, 2003
    10
    North East Texas
    Thanks, Dose it matter the year of the truck they are comming out of??
  4. heavy4x4
    Aug 28, 2002
    3,270
    '73-on
  5. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    put an 80 under my 91.... off-the-shelf U-Joint with large/smaller sides to it (NAPA number posted on here somewhere)... Mine was also a step up in brakes, so needed some items there..... some brake fluid.... New U-bolts recommended (14 is bigger!!) and the plates from donor vehicle if possible....
    and mine was a change from 6 lug to 8, so a set of tires were needed too! /forums/images/graemlins/smile.gif
    Oh, and most important.. the case of beer to cover labor!
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    14 FF didnt exit until 73, and before then were the eaton ho52 and the dana 60, 2wd versions of these from a 63-72 will bolt under a 73-87 to but oen shock mount needs to be relocated
    ratios in eatons were 4.10, and 4.57
    danas were 4.10 and 4.56 with a very uncommon 3.54
  7. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    You will also need the ubolts from the donor truck.
