14 bolt fitment question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 96texasz, Dec 2, 2006.
  1. 96texasz
    96texasz Registered Member
    Nov 13, 2006
    28
    Wichita Falls, TX
    will a 14 bolt out of a 79 2wd chevy 3/4 ton bolt right up to a 86 blazer without moving spring perches or shock mounts?
  2. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    possibly just shock mounts. but perches will be fine. search in the garage. covered a bit there more than in hear.
  3. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    Will bolt in with no trouble but I do not know about the shocks so try it I have used many 2 wd 14 bolts in my trucks without moving shock mounts. I did always have to go to a longer shock. Try and see what happens.
    bigred81
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    It will be a direct bolt in shocks included. The only difference between 2WD and 4WD are the shock brackets hang about 2-3" lower on the 2WD axles. You might have to modify the driver shock mount unless you run your shocks upside down because the shock body might hit the mount before you align the bolt hole up.
  5. 96texasz
    Nov 13, 2006
    28
    Wichita Falls, TX
    thanks for all the help i appreciate it.
  6. basketcase
    basketcase Registered Member
    Apr 30, 2005
    52
    buffalo,ny
    just did that swap myself yesterday, the shock mounts lined up fine as did the pearches. you need a hybird u joint, #210-0447 @ napa
