14 Bolt Front Axle
Discussion in 'The Garage' started by Ryan B., Mar 9, 2002.
  1. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Call this BS...
    <a target="_blank" href=http://coloradok5.com/gallery/albuo19/abk?full=1>14 Bolt Front Axle!</a>/forums/images/icons/shocked.gif/forums/images/icons/smile.gif
    I was in disbelief when i saw it too.
    Some of us have talked about 12 bolt fronts and 14 bolts fronts but i've never seen a pic of a "real one".
    A buddy of mine that was taking auto classes with me was trying to build one for his Jeep. I told him after he did it and got the bugs figured out i'd buy one if he built it for me./forums/images/icons/laugh.gif
    Seriously though, I was thinking how cool would that be to have a custom 14 bolt front axle... You know that people would be doing a double take and coming over to ask you questions about it.
    It seems like there's only two ways about it either somehow having a place press new axle tubes into the center housing with the passanger side tube shorter and the drivers side longer etc. which would be a pain,
    Or somehow re mount the T-case so both front and rear output shafts would be centered... (Which it looks like this guy did... just leave the axle tubes alone keeping the center housing centered and get the t-case output to be centered horizontally for the front and rear outputs.)
    Only thing i can think of is clearance issues if you could rotate the t-case that way... then it seems like it would hang really low. Lower than normal... And moving the rear crossmember so the t case could hang down lower would probally be required. Seems like it would be too low even with a skid plate.
    I'm want to look into this now and go talk to the place that was going to help my friend with his 14 bolt front he was attempting to make.
    Anyone think of a way to make it possible?
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    why?
    you are going to cut up a 60 to make a POS
    I guess if you used ends and shafts from a dana 50 i can forgive you
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I guess what i'm saying is if i got a cheap 14 bolt and could find the other parts to make it a front end... but i suppose the only real way to go would be to use the 1ton D60 stuff to make it a front end. And your right in that sense why f*ck up a D60 for that?
    If i got my hands on a Dana 60 do you think i'd cut it up and use the pieces to make this 14 bolt front? Uh no.
    I'd have a Dana 60 front under my truck.
    Just brainstoming./forums/images/icons/shocked.gif/forums/images/icons/smile.gif
    ...Dana 50?
  4. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    <blockquote><font class="small">In reply to:</font><hr>
    Dana 50?
    <hr></blockquote>
    Glorified D44 outers...bigger ring and pinion. Found under F stupid duty's./forums/images/icons/smile.gif Prolly wouldn't have Death Wobble though.../forums/images/icons/wink.gif
    Rene
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    u sure?
    huge hubs
    look a lot like 60 spindles n lock outs
  6. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i have a pics of one too . ill post it on my pics page . oh and by the way wagoner machine makes 14 bolt front ends custom of course.....
    <a target="_blank" href=http://wagonermachine.com/corp_14.htm>http://wagonermachine.com/corp_14.htm</a>
  7. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    There is a jheep in the new 4wheeloffroad that has a front 14 bolt. The thing looks huge. I think there is just may to many modifications to it to make it work. By the time you get everything fabbed up to make it work, it probably would have been cheaper and definetly easier to just by a front D60.
  8. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    I've seen the Wagoner guys running the 14 bolt fronts up a at Disney. I think it was the blue jeep. They're pretty sweet. I think it's just something to do to be different rather than stronger. I guess it is stronger but not that much.
  9. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    The 14 in that pic is owned by John Sumner of Waggoner Machine Shop (WMS). I have a friend Steve Sharp who wheels with him all the time. This is definately a trick setup. It was cool, one day on the way to Disney - Layne (K5BLT4FUN) and I were chatting about building a 14 Bolt frontend. The Bizzare thing is,we arrived at Disney and at the Gas Station was John's rig with 14 front. It was deja-voodoo! I talked to him about this axle. He said it is a marketing tool more than anything. They can build these axles fairly easily. He used D60 outers and retubed this axle. I believe the axleshafts are re-splined 35 spline outers from a D60. He said its a little pricey, but they can build them. It would be nice to have the same gear setup front and rear.
    The thing about this setup is - He wheels the crap out of it! It doesn't sit in his driveway. I have 4 hours of video from this rig doing the impossible. If you look for it in Disney in the future, it will be flat black in color.
    First of all, you don't have to cut up your gold plated D60 anyway. You can buy the outers all new from Dana, inlcuding the housing ends. So, why do it? Why not? When you own a machine shop and can fab some wild stuff, its all in good fun. Did you notice the trussed 14 bolt on the Waggoner site? I bet they didnt add that because it looked cool.
    M_J tell us why this axle is a POS.
  10. ChadH82
    May 9, 2001
    400
  11. Mudzer
    3,639
    Missouri
    Its been on there since I met him last year. I will ask Steve Sharp.
    Not sure who that guy is, I have seen him wheel, but don't know him. I know John owns the Scrambler, with YJ body and exocage. I believe the photo you showed is a guy with Rockwells. John's is the only one from the Waggoner group who runs the 14 front as far as I know.
  12. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    I wouldn't say the axle was a POS, but it would have a lot less clearance than a D60. I think the carrier part of a D60 is more than strong enough that going bigger is unnecessary. It is a good marketing tool though.
    Rene
  13. Mudzer
    3,639
    Missouri
    Another negative thing for us non-machine shop owners - you have to make custom shafts for the front. We would have to buy them directly from the machine shop if the unfortunate would happen. I guess for a guy who works there, its a cool idea. I do agree a D60 is as strong as this axle.
  14. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    I think they should have built a 12 bolt front.../forums/images/icons/smile.gif
    Rene
  15. Mudzer
    3,639
    Missouri
    Currie rates a D44 as strong as a 12 Bolt.
  16. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    not as strong as mine ! bwahahaha
  17. Mudzer
    3,639
    Missouri
    Id be willing to bet mine is as strong as yours! Bwaaaahhahahahaha! I have the same parts you have!
    We are both probably nuts for spending major amounts of cash on 1/2 ton stuff. I will grow up someday.
  18. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    "M_J tell us why this axle is a POS. "
    cause it doesnt have a MOO truss glued to the top of it?
  19. blazerboss 85
    blazerboss 85 Banned
    Nov 21, 2007
    560
    grass valley CA
    14 bolt fronts are stronger than 60's
  20. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    hay nobb why dig up a thread thats 6.5 years old just to make a smart coment. come on man . :doah:
