????????? 14 bolt front axle ???????????
Discussion in 'The Garage' started by Z3PR, Aug 11, 2002.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Some parts counter jocky told me I should put a 14 bolt front axle in my Blazer. /forums/images/icons/confused.gif I've never heard of one. /forums/images/icons/confused.gif Is there such a beast ?????? /forums/images/icons/confused.gif /forums/images/icons/confused.gif /forums/images/icons/confused.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    No such thing unless you have one custom made.
    Wagoner Machine Shop in Oklahoma makes them. They have a pic up on their site.
    Check out wagonermachine.com to see the pics. /forums/images/icons/wink.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'll be looking into that. Might be worth doing. /forums/images/icons/grin.gif
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    14FF front axle = high $$$$$ /forums/images/icons/wink.gif
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Worth it? D60 might make more sense.
  6. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    The only benefit is the stronger ring gear. Is it worth it? To some. But not to all.
    Neat gadget axle though.
    Ken H.
  7. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    The only people I have heard of needing a 14 bolt front are the high horsepower mud boggers. They can wipe out a D60 Ring and Pinion because their wheels are for the most part always straight. If your wheels are turned the joint will give before the R&P. Nice conversation piece though
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Probably not since the front axle probably sees approximately 10 - 15% use when the rear is used 100%, depending on how much off roading the driver takes the truck out.
    Sure the custom-made 14FF front would be worth it to those who do more hard core and serious off roading, mainly like the rocks or mud, but not for a daily driver or anything that you need to drive every now and then. /forums/images/icons/wink.gif That's what the D60 is for.
  9. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Custom front 14bff usually use Dana 60 outers anyway, so why bother?
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I can see the need for a heavier front for some situations, but why a 14 bolt bolt over say a dana 80 front? Parts would be more rare but locker and gearing options are much more available than the 14 bolt.
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    EXACTLY!! /forums/images/icons/wink.gif
  12. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    well, some peeps think that if u convert a d60 to 35 spline throughout and use beefy-trick u-joints that your ring/locker etc may become the weak link in the system. If u had a 14b or d70 (or whatever) center, that problem is solved... and the weak point is once again the u-joint. /forums/images/icons/wink.gif errr or something like that, lol!
    J
  13. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Wonder what the costs would compare to just getting a Rockwell. By the time you take a 14 bolt or similer and make it a front end, a Rockwell might be cost effective. That is if you have a problem with trashing the ring and pinion on the D60.
  14. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    rockwells rock... but only having 6.92 (or is it 6.72?) as a gear ratio could be annoying on a daily driver...
    J
  15. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    Not too bad if your sitting on 44's... /forums/images/icons/wink.gif
    Sounds like a good excuse for the wife as to why you need such "big tires". hehe...
  16. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    My buddy runs Rockwells on one of his trucks.
    He almost regrets it but not quite. We both love to mud race and mud bog but the rules around here exclude him and his setup. He repainted it and now drives in Parades. We also have a small reservoir that the local mudders play in. He cant even go out there. He sinks like a rock and we all drive circles around him. He only uses it a few times a year.
  17. thatK30guy
    Jan 12, 2001
    32,076
    55
    6.72 is the ratio. /forums/images/icons/wink.gif
    Wouldn't be bad if the tires are 48" tall. /forums/images/icons/cool.gif
  18. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    6.72... its like having a doubler... but not! /forums/images/icons/wink.gif man, with a doubler... np205 3:1 kit, 2.5t rockwells, and a manual trans you would have a pretty swizeet crawl ratio! LOL! /forums/images/icons/wink.gif
  19. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, you sure would! /forums/images/icons/cool.gif
  20. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Subject:
    Re: 14 Bolt FF axles front and rear
    Date:
    Wed, 14 Aug 2002 11:45:04 EDT
    Cyclura98@aol.com
    To:
    Z3PR@NETSCAPE.NET
    A Corp. 14 front end will probably not work in a Blazer front end due to the offset of the pinion in a passenger side application. A
    Corp. 14 rear end with 4.56 gears, a Detroit Locker, and disc brakes runs $1700.00. An open front end complete w/shave and cover
    would run about $7000.00. Please let me know if you have anymore questions.
    Casey
    W.M.S.
