14 bolt full floater lube capacity
Discussion in 'The Garage' started by BigBurban350, Nov 27, 2002.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I have a 14-FF from a mid 80s truck, what is the gear lube capacity? /forums/images/graemlins/burb.gif
  2. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Seems like mine took almost a full gallon of gear oil. That was from "bone dry" to completely full.
    I also rotated the rear wheels on jackstands to get the lube to the outer bearings for a few minutes, then topped off again.
  3. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    yeah i remember pumping darn near the entire gallon into it before it was full...
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I only got about 3 quarts into mine. When I first filled it I only got about 23/4 quarts in. Then I went back and refilled after it had time to get to the outer bearings. I refilled and it took another 1/4 quart. I do have a "thick" 4.56 ring & pinion in there, so that might be part of my lower capacity.
