14 BOLT Full Floater / Semi Floater
Discussion in 'The Garage' started by MNNCO, Sep 2, 2004.
  1. MNNCO
    MNNCO Newbie
    Nov 7, 2002
    4
    I'm new to the forum, I finaly need the resources.
    I will most likely buy a year membership, but would like to see how it goes on the forums first.
    Thanks for the opportunity! /forums/images/graemlins/thumb.gif
    I think this is appropriate material for the Garage.
    Just getting started on a 70 K5 and I have a few questions.
    Can a 14 bolt SF be converted to a FF?
    I know a guy that has a Dana 44 and a 14Bolt sf 3/4 ton 4.10 gears for $375. Is that a fair price?
    They are in a good running truck that is donating it's Big Block.
    The Blazer has the stock 12 Bolt and Dana 44 with 3.08's.
    Seems this would be a step up to me. It will also give me disk brakes!
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    what size tires are you planning on running, and what type of wheeling do you do??, no you cant convert a SF to FF the 2 axles look completely differnet, the sf is pretty strong but the FF is alot stronger it just depends on what you are going to be doin.
    -Chris
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    welcome to CK5 /forums/images/graemlins/waytogo.gif
    a sf can not be converted to a FF, its a totly different axle. warn sold a kit for a 10b/12b, but it was expencive and they discontinued them.
    $374 i think is a good price for a set of 3/4 ton with 4:10s, they didn't come with disks unless he swaped them on it.
  4. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    not sure on if you can convert it to FF...probably I know warn makes some FF kits...but it wont be as burly as a true 14bolt FF which has a 10.5 ring gear whereas the semifloater has a 9.5 ring gear...I'd say just run it...u can always find a 14Bolt FF for pretty cheap and swap it in later down the road!
  5. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    I think he's talking bout the front...since in 70 the fronts used drums /forums/images/graemlins/thumb.gif
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif forgot about that /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif
  7. MNNCO
    MNNCO Newbie
    Nov 7, 2002
    4
    Thanks for the help!
    These axles are in a early/mid 80's 3/4 ton chevy truck. I have not seen the rear axle, but it sounds like it is a sf. Maybe it is a ff? The seller doesn't know for sure.
    I'll know for sure this weekend when I look at it.
    Discs, yes I was refering to the front axle.
    The stock drums are really bad!
    I am in the process of installing a BB 396 , and plan on running 35's. I plan to drive it 50/50 on/off road.
    Hopefully after a few mod's like a cage and bumpers I can be off road more.
    I guess for the money, it will take care of the gear problem and help the brakes on all 4 corners, and give me stronger axles. not bad for $375. Couldn't do a gear swap for that.
  8. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    If it is an 80's K20 then it should most definitely have a 14sf.
  9. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    why? /forums/images/graemlins/confused.gif actually most but not all k20 came with a FF it wasn't untill after 87 that they really started using SF's in 3/4 tons
  10. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Are you sure? My '82 has a sf and most 80's 3/4 ton subs that I know of have the SF. I think C20s may have gotten the FF more often.
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i agree, its hard to find a ff in a 81 and newer k20. between my buddy and i, we have 4 81 and newer k20s and all are sf
  12. beater74
    May 29, 2001
    1,749
    atlanta
    i stand corrected /forums/images/graemlins/smirk.gif
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    81-up ALL K20s should have the SF.
    Reason the 14 FF can be found in C20s is that they had the option for a 454.
  14. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Welcome!
    The SF rear is a fine axle for moderate wheeling especially with 35" tires but a locker is more expensive than for the 14FF (it uses the existing carrier so its cheaper). The front axle is prolly a 10 bolt instead of a D44 but they are virtually identical in strength and ok for moderate wheeling. You should actually get a strength increase over your current 1970 D44 because the axle u joints in the later D44's and all the front 10 bolts are considerably larger, so you'll have disk brakes and larger axle joints.
  15. gonecheenin
    gonecheenin 1/2 ton status
    Aug 8, 2004
    111
    Vandergrift, PA
    How much stronger is the 14bsf than a 12 bolt?
    From bearing spec's i've found, it look's like the internal parts are quite a bit larger, just curious about real world comparisons? /forums/images/graemlins/thumb.gif
  16. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i think the sf is alot stronger than a 12b, i think its just a little weaker than the FF. the big difference is strenght is the SF design and the 1" smaller ring gear.
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A 12 bolt would be lucky to hold up to 35s under hard use.
    I'd say an SF could take a 38x12.50 no problem.
    As far as semi floating axles go, 14 SF is the king along with the Dana 60.
    FF is still far better IMO though. I ran a 14 SF hard for two years without breakage though.
  18. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    ive had my sf for about a year wiht 38.5 tsls on it, never a problem
  19. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I paid $250.00 for my 3/4 axles. (Dana 44 front / 14 Bolt FF rear).
  20. gonecheenin
    Aug 8, 2004
    111
    Vandergrift, PA
    I'm going from my welded diff 14bff in my 74' K20 to a locked 14bsf for the weight savings and ground clearance gains (plus the fact that you can get to the brake shoes without using up an entire day wrenching)
    just wanted to get some real world comparisons from guys who have used them.
    Since all my twelve bolts have held up pretty good (except for the Gov-Lok one's, man what junk that idea was /forums/images/graemlins/angryfire.gif) i figured i shouldn't have any problem with the bigger axle
    i only run 36" TSL radials and wheel in PA (kinda slippery up here), so it sounds like the 14bsf will be great for what i do.
    Thanks again guys /forums/images/graemlins/thumb.gif
