14 Bolt Full Floater
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by clubba68, Jun 11, 2003.
  1. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Is there any way of telling if an axle is a full floater vs a normal 14 Bolt? Any markings or anything that would distinguish one from another? I have found a 14 Bolt full floater for $200 and just want to make sure that it is an actual full floater.
    Thanks for the help guys,
    Andrew
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Full floaters have the hub in the middle.
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    14FF:
    14SF:
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    from the axle info:
    "The "small" GM 14-bolt has a 9 1/2-inch ring gear diameter. It was used in the rear of 1964-and-later GM pickups, and in the rear of 1984-91 3/4-ton Suburbans."
    I know this axle wasn't used in 67-72 trucks. The only 3/4 and 1 ton rearends were the dana 60 and the eaton ho52/72. i guess there was a sf dana 60 found in some BB 1/2 tons, but no 14 bolts.
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I beg to differ here...I used to have a 72 C20 years ago with a factory 14FF
  7. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    That's cool - must have been one of the very first ones...
  8. 72beater
    72beater 1/2 ton status
    Oct 11, 2002
    224
    Nation\'s Capital
    will that d-60 from the first gen 1 tons bolt right up in a first gen k-5?
  9. u2slow
    May 9, 2001
    2,217
    BC Canada
    For every so-called "info" sheet there should be a "corrections sheet /forums/images/graemlins/rolleyes.gif. This rear axle didn't appear until '81 and is still in production.
    Should work... the 1-ton (and 3/4-ton longhorn) D60 have 40.5" spacing and both shocks inboard & angled forward.
  10. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    i think that the dana 60 was only found on some 67-72 3/4 ton trucks...the 1 tons all had eaton ho72's, and 3/4 tons had the ho52. most seem to have the eaton.
  11. 72beater
    Oct 11, 2002
    224
    Nation\'s Capital
    that Eaton is a beast for spare parts, right?
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    oh boy...
    no 14 bolt FF til 73, everything before 73 had 10 bolt covers no matter if 60 or eaton
    ho52 and h073 were the 3/4 and 1 ton axles from 47 to 72, only difference between the two were brake size just like from 3/4 to 1 ton 14 bolt FF
    dana 60 were in alot of trucks 3/4 ton 72 and older, most all were leaf sprung
    67-72 2wd except longhorn and 1 ton were coil spring or 42.5" leaves
    4x4 and 1 ton and longhorns 72 and older were 40" centers
    any of the 42.5" axles will go under any trucks with 42.5" packs, but shocks moved to both sides of axle in 73
