14 bolt gear problem?? !!updated!!
Discussion in 'The Garage' started by chulisohombre, Apr 8, 2003.
  1. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    how much play should the gears have in a 14ff?mine seems to have too much and makes noises when i let off the gas.when i turn the pinion it has about 1/2 inch to an inch of play in the gears.can i adjust the gears to mesh tighter by using the adjusting caps the hold in the carrier bearings?or is that just a bearing adjustment and not a side to side adjustment?it almost slips a little when i let off the gas and get back on it.my 12 bolt was not even neer as loose when i compares the pinion play.it seems that the gears are not meshed tight enough.any help is appriciated.dont want to blow up the 14 bolt just got it in there this weekend.
    UPDATE:pulled the cover and the spiders are loose.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: 14 bolt gear problem??
    <font color="green"> That can be adjusted with the adjustment rings on the carrier bearings, but you want to make sure that that is the actual problem. I would suggest pulling out the pinion in it's housing and checking to make sure that the play isn't there, then take a look to make sure that the carrier bearings haven't come out of adjustment and that the little metal locking tabs are in place. If everything looks good then get your hands on a dial indicator and reset the backlash to about .008". You should run a pattern on the gears after this just to make sure that everything looks good, just making random adjustments to gears is never a good idea... </font>
  3. Nikk
    Nikk Registered Member
    Dec 16, 2002
    34
    Lacrosse, WI
    I'd like to hear more about this. I have a 14sf that seems to have too much play. Mine seems to clunk real good when put into reverse ( no the u joints are fine). Everything seems tight pinion wise, no up and down or side to side movement. There is rotational slop though like mentioned in the post above. Is this normal to have to adjust these rears? I didnt mean to take over the post just hoping to get info to help us all, Thanks Nick
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It's not normal to have to adjust them, but it could be that there is no problem and the clunk is just the driveline slack being taken out. There are parts that might have a little slack, which when added up could seem like alot. The backlash, any play in the spiders or u-joints, there's really lots of stuff, this could be fairly normal.
    On the 14b SF, there are no adjustment rings, so if you have a whole lot of slack then you will ahve a harder time fixing it. For either of you, now that I think about this, a backlash measurment before anything is taken apart would probably be a good place to start. If that is in spec then don't worry about it. </font>
  5. Nikk
    Dec 16, 2002
    34
    Lacrosse, WI
    Thanks Shaggy,
    I've been driving it like this for some time so I too think it's not realy hurting anything. Thanks for the info, I'll have to check the backlash next time I have the cover off. I'll probably end up finding something else that's causing the excess slack. Thanks again
  6. bogginnut
    bogginnut Registered Member
    Jan 6, 2002
    82
    Jacksonville, Florida
    Sounds to me like you've got a Detroit in there.
  7. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i wish having a detroit was my problem.there is no slack anywhere else in the driveline.i can take the pinion and rotate it about 1/2 inch to an inch in either direction before it grabs the gears on the ring gear.i know this is way too much.i think maybe the carrier was taken out by a PO and not set backlash right way.i got it out of a junk yard.the truck had 60000 miles on it and was a company truck that just drove around the company yard.about 2 square miles.so i wouldn't think that there would be something worn out on it.i think maybe it just needs to be adjusted correctly so that the gears mesh right.it starts to wine a little when i let off the gas. that was the noise im talking about in my first post.and then i tried to go and let off on the gas and go again and it popps into place when the slack in the gears gets taken out.how exactly should i check backlash.my buddy just got a dial indicater but nether of us has set up gears before.i think randys r&amp;p has a guide but im not sure about some of the stuff in there when i read it before.any tips on how to easily check would be appriciated. /forums/images/graemlins/smile.gif
  8. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> OK, first thing is that I'm not sure how you can measure rotational slack in inches. Also, 1 inch is twice as much as half an inch, so that's a pretty big difference. Any idea how many degrees of slack there is? You might be surprised how much slack there can be in axle splines... I bet if you pull the cover you'll find that there is not nearly as much slack between the ring and pinion as you think. </font>
  9. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    when i pulled the cover to check everything out before throwing it under my truck,it seemed loose then.but this is my first 14 bolt and i thought maybe it is supposed to be that way.i also thought that once i got some gear oil in there it would be a little tighter also.i would say that the free play between the gears is around 10 degrees.measureing slack in inches i was saying that i could rotate it about a 1/2 inch in either direction between hitting gear and the pinion stopping.degrees is a better assesment of play though.
  10. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    ttt
  11. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    any body else ahve any answers
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Run a pattern on it to see how it looks, that about all the suggestion I have left. </font>
  13. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Here is a pretty good tech article. Its got good illustrations for checking the pattern and using the dial indicator. I am learning how to do all of this myself right now. Hope this helps.
    Click download pdf file
    http://www.ring-pinion.com/installation-kits.shtml
    -Brian
  14. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    guess i'll have to open it up and check the backlash and stuff.thanx for the help.
  15. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    ok,now i pulled the cover and the spider gears seem loose to me.how much play should they have?they move about 5 degrees which is where my play comes in the axle.should it have that much play before engaging to the axle shafts?the gears themselves look good and the spider gears look goood,but the cross shaft move a little when i move the carrier back and forth.should i worry about the spiders falling apart or anything?im trying to get the money together for a detroit but $314 is gonna be a couple of months away for me to be able to afford.
  16. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    ttt one more time.
  17. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I don't think that the crossshaft should be moving, but if you're going to get a detroit anyways then I wouldn't worry about it. </font>
  18. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    it wiggles around in the housing a little when i turn the carrier.hopefully the carrier is not junk.could just the crosshafts be worn out to let them wiggle around?or will the carrier be loose with a detroit crosshaft in there also?i thought that when you torque the ring gear on it is supposed to lock the crosshafts in place and just the spiders spin on the crosshaft.i checked the bolts to make sure they are tight.
