14 bolt gear swap ?'s
Discussion in 'The Garage' started by outlaw612, Feb 10, 2004.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    14 bolt gear swap ?\'s
    Im swapping gears and carrier in my 14 bolt. Where is the best place to buy a bearing/seal kit? Where can I get an oversized(ID) pinion bearing to use for setup?
    Also, does anyone know of a good write up for a 14 bolt gear swap? The one here in the Tech section is pretty vague.
    Thanks guys.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Re: 14 bolt gear swap ?\'s
    You don't need an oversize bearing for setup on a 14FF. The shims bolt on with the bearing support.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I got mine from 4WP I think all Timken bearings.
    Randy's
    West Coast Differentials
    There is a PDF tech article that is pretty good on Randy's /forums/images/graemlins/thumb.gif
    Few Threads I saved during my install
    How to
    Torque specs
    Hope it helps /forums/images/graemlins/thumb.gif
  4. outlaw612
    Feb 11, 2001
    2,342
    Thanks Guys
