14 bolt gears ?
Discussion in 'The Garage' started by screamer*145, Apr 27, 2006.
  1. screamer*145
    screamer*145 1/2 ton status
    Oct 23, 2003
    174
    cottage grove, mn
    The gears in my 14 bolt now are 4.09s and I want to get a set of 4.56s for it and was not clear on weather or not I will need a diffrent carrier for them or not. If someone could point me in the right direction that would be great.
  2. bdozeraz
    bdozeraz 1/2 ton status
    Nov 8, 2004
    212
    Phx, Az
    I believe the break point is 4.11 and up. You can get 4.56 gears that are thick to fit the other carrier. Where ever you order them they should be able to get you the right gears for the carrier. They should have the information that tells them what the break point is.
    Brent
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    You can use your same carrier. Just get the thick gears. If you want Yukon gears, the part # is YG GM14T-456T (fits 4.10 & down case).
  4. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    thanks for the info guys :waytogo: and shane I got my zero rates in the mail on tuesday and again great product. keep up the good work.
