14 bolt gears
Discussion in 'The Garage' started by 76k5Blazer, Apr 22, 2003.
  1. 76k5Blazer
    76k5Blazer 1/2 ton status
    Sep 25, 2002
    176
    tracy ca
    how do you decode the ratio from the stamped #s on the ring gear these are stock gm gears
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    They stamp it with the number of ring gear teeth and the number of pinion gear teeth.
    For example, if it says 41 10 then you divide the two and it's 4.10
    If it says 41 11 then it's 3.73.
    -- Mike
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    It's stamped on the "nose" of the Pinion shaft, [small end]
    of the shaft. 41/10 etc.
