14 Bolt Help, Quick
Discussion in 'The Garage' started by 79Stomper, Aug 1, 2004.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    All right just got home, pulled the 14 bolt out of the back of the Cherokee. I need to I.D. The gear ratio.
    This is stamped on the ring 3 GM 464917 12 45 3 81
    Is there the gear ratio anywhere in here? /forums/images/graemlins/confused.gif This is my first 14 bolt so would like to know if I need to start counting teeth yet.
    Also there was a metal shaving in it. Seemed to be like a shim of some sort. it was stuck to the bottom in a pile of sludge. Don't think the rear was ever PM'd.
    TIA /forums/images/graemlins/thumb.gif
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i usually just count teeth, but it looks like there could be 45 on the ring gear,and 12 on the pinion, giving you 3.75...or ~3.73
  3. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Thanks, I see it now. I just couldn't figure out which numbers it was but now I see. Done it no probelm a few weeks ago with a Dana 60 but this one stumped me. I am a simple minded person and there were simply too many numbers.
    James
  4. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    12 45 3 81
    Yep, should be 45 teeth on the ring gear and 12 on the pinion.
    The casting date should be March of 1981 (3 81)
