14 bolt help?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78 k5, Sep 5, 2004.
  1. 78 k5
    78 k5 1/2 ton status
    Jul 8, 2004
    261
    Auburn, AL or ATL, Ga
    My stock K5 driveshaft won't match up with my new 14bff. What is the U-joint on my driveshaft (1310/1350/1410??) and what is the Pinion yoke on my 14bolt??? How do I fix this problem?
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Your driveshaft is 1310. Your axle is 1350.
    There is a conversion ujoint. I do not know the part number, but someone else will and you can get it from NAPA.
    A better choice would be to upgrade your driveshaft to 1350.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Napa/Precision PN 348
    Neapco PN 3-3140
  4. 78 k5
    Jul 8, 2004
    261
    Does it matter that its out of a 3/4 ton? Or is it still 1350?
  5. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Just an FYI some 10bolts did have the 1350 yoke on them. My 83 6.2l had a 1350 on the 10 bolt so the driveshaft was all set on my 14bolt swap with no ujoint change or conversion joint.
    My 14 bolt was from a 3/4 ton 73K20.
    Don't ask me why they put such a large ujoint on such a small axle /forums/images/graemlins/dunno.gif
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I have never seen or heard of a 1350 on a 10 bolt but they did use 1330.
  7. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Some 80's model K5 stock with sm465's came with 1350's in the rear driveshaft. Mine did.
