14 bolt help!
Discussion in 'The Garage' started by ssped, Sep 6, 2006.
  1. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I need an opinion. I have a woble at the rear wheel when spinning at freeway speeds. you can see the center hub and axle wobble when spinning in the air. It is not a bent axle tube, I have deduced that and nothing is loose. so as to opinions the parts store says replace the bearings but I am thinking it is going to be whole Hub. the assy came from a junk yard and so I am not sure the history on the parts. could the bearings be out of roand causing it? would they not make noise or be loose? how posible is it to warp a Hub on a rear 14ff?
    thanks
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Are you sure that the bearings are not the cause?
  3. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    my first guess would be the wheel bearings. Ive heard of people fubaring the hubs when they destroyed the bearings but I think its pretty hard to warp one. I know several people including me that have chewed up the bearings pretty bad without hurting the hub but it is possible.
  4. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    I had to have the drums turned when I picked up the axle. they were pretty warped. I am now rethinking the fact that the hub mught have been warped and the drum fine. would not a bad bearing have signs of an issue with it? IE loose or something? I just dont want to put bearings in a bad hub. I have a bore mic. I could probably measure the races.
  5. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    Do you know if they took the drums off the hubs to turn them ?
    if so , then its possible that the drum and hub are not completely seated together.
    i would also find out if the bearings have been replaced , its possible
    that they did not seat a race properly.
  6. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    They turned them on the hubs so they are true to the drums. I am going to replace the bearings and races tomorrow and see if it makes a difference. it was a used diff from a junk yard so who knows what was done or is wrong. I have never seen bearing failure this way. I also just picked up a new set of premium Warn hubs to do the front 8 lug conversion. I will have that done this weekend too. (with new Bearings) should be a succesfull weekend.
