14 bolt hub bearing removal --Now with poll on bearing lubercation
Discussion in 'The Garage' started by mostwanted, Feb 11, 2007.
  1. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    I finally picked up a hub socket and have the time to take them apart. I removed the spindle lock nut but there was no lock washer. There was a snap ring. According to Billavista's article on pirate there is a lock washer with tabs that I am supposed to bend out of the way. Then behind the bearing there is another inner nut. It looks as if the hub will not come off without removing the bearings at the same time. It appears that the outer circumfrence of the bearing is larger than the inner hub housing. Do I have a odd style hub or am I doing something wrong?
    link to billavista's article:http://www.pirate4x4.com/tech/billavista/14b%20disc%20brakes/index.html
    from billavistas article:
  2. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
  3. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    if yours has the snapring, you will need to remove the outer nut, remove the snapring, and get a small steel key out of the groove in the spindle(should be in there loose, was held in by the snapring), then remove the inner nut
    the bearing will stay in the hub, if you want them removed from the hub, they come out from the inside end of the hub
    P.S. they are oiled with gear lube from the axle
  4. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    I got all that stuff out. I guess maybe the brakes are holding it on. I have been beasting on the drum hoing that it would slide off. I just don't want to score the spindle or mess up any threads while swinging my BFH.
  5. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Might need to back the brakes off a bit to get that drum over the shoes.
  6. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    Okay, I backed the brakes off a bit and I have been beating the living crap out of it. I still think that there might be a nut or something behind the bearing. Does anyone know for sure? It feels like it is loose from the brakes but there is something holding it back. I can get the drum to move say 1/4 to 1/2 inch then it stops. I am very fustrated. Guess I will try again tomorrow.
  7. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    Use a deadblow hammer or rubber hammer instead.. it will take some jiggling side to side to get it off. I had the same trouble getting mine apart.
  8. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    I'd say you still need to back those brakes off some more. If you pull it untill it stops, can you turn the drum? If not, it is probably hitting the ridge on the drum.
  9. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    Yes, I can turn the drum. I have even been prying on one side while striking the other.
  10. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I couldn't my drums off after adjusting the brakes as much as possible so I ended up cutting the pins that hold the shoes to the backing plate.
  11. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    what pins are you refering to that you could access with the drums still intact?
  12. goldwing2000
    goldwing2000 Guest
    The hold-down pins that attach the shoes to the backing plate. They stick through at the 3:00 and 9:00 positions.
    If you can still rotate the drum, I have my doubts that it's the brake shoes holding it on, though. Unless you have a seriously worn drum and a massive rust ridge.
  13. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    I got them off. I wound up knocking the heads off the bolts that go thru the wheel cylnders. The whole thing slid off brakes and all. Now I have another problem getting that inner snap ring out of the hub. It is stiff! The biggest pair of snap ring pliers I have are about 8" and it wouldn't even budge.
  14. 58 apache
    58 apache 1/2 ton status
    Aug 26, 2006
    377
    clarksville,Va home of the body bag
    bend the corner at the split and grab it with needle nose plyers. that was the only way i could get mine off
  15. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Long set of needle nose vise grips and a couple flathead screwdrivers. It takes some strong words of encouragement too usually.
  16. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Also drive the race toward the outer edge of the hub. This will open the gap that the snap ring sits in and will make it slightly easier to get out. I used a set of needle nose pliers and got one end out then put a flat tip screw driver in there to keep it from slipping back in. Work the screw driver around and it will come right out.
    Ira
  17. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    great. Thanks for the tips. I will try that in the morning. I am thinking of painting the axles with por-15. I found some sold locally.
  18. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    I bought this
    but it wasn't strrong enough. So I took some of Manny's spinich and dug that son of a buck out with a set of huge noodle nose vise grips, big pick, and a punch.
    Now the blasted bearing and rase wont slide out like I had hoped. Whats's the deal? At least when I am finished, if I use quality bearings, I shouldn't have to do this again!
  19. sandawgk5
    Oct 28, 2003
    6,881
    The race has to be driven out it is in there pretty tight.
    Ira
  20. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    would this work? I don't wanna damage nothing.
