14 Bolt Hub Rebuilding?
Discussion in 'The Garage' started by 8t7jimmy, Mar 27, 2006.
  1. 8t7jimmy
    8t7jimmy 1/2 ton status Premium Member
    Mar 2, 2004
    137
    West Lafayette, Indiana
    Does anyone have information on rebuilding the Hubs on a 14 Bolt? I have all the parts and new bearings and seals, but i need some info on the proper way to reassemble them. When i got the axle, it was disassembled. If i was the one that took them apart, i would be okay.
    I have searched, but haven't found anything on the hubs. Pirate has lots of info, but nothing seems to go into detail on the hubs.
    Any help would be appreciated.
    Ryan
  2. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I found this information pretty helpful http://www.pirate4x4.com/tech/billavista/14b_bible/index.html
    but when I had to rebuild mine it was on the side of the road, in the rain, and I had never done it before. Thats how I learned to put one together.
    edit: just saw the part where you said pirate didnt help
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    its basically like the front. big bearing/race on the back side w/ seal, front smaller bearing w/ spindle nut/lock ring/nuther spindle nut.
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    On a 14FF you have to put the outer bearing in first then press the race in from the back side. Then you can put in the large race and the other bearing then the seal. The ID of the hub where the axle flange seals is not large enough to let the bearing and race to come out. I know Billa Vista addressed this in his article.
    Ira
