14 Bolt Hub Rebuilding
Discussion in 'The Garage' started by 8t7jimmy, Jun 7, 2006.
  1. 8t7jimmy
    8t7jimmy 1/2 ton status Premium Member
    Mar 2, 2004
    137
    West Lafayette, Indiana
    Does anybody have an exploded view and assembly instructions for 14 Bolt hubs? When i bought my 14 Bolt it was disassembled, so i am not sure how it all goes together. Pirate has a lot of info, but nothing on the assembly of the hubs. I found a thumbnail exploded view on Pirate, but that is all i can find.
    Sorry for the newbie question, but i can't find anything when i search.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
  4. 8t7jimmy
    Mar 2, 2004
    137
    Thanks! That helps, but still a few questions. Do the bearings / Races get pressed in or can i put them in by hand?
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I always just use a punch and a hammer. I don't remember, but I think it's the outer bearing you have to put the bearing in and then knock the race in then there is a snap ring. It's been awhile since I have had mine apart.
  6. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    install the inner and outer races with a brass punch,drop in the inner bearing,install the seal,put hub on spindle then install outer bearing,install 1 nut and tourque to spec,install locking ring then outer nut and torque to spec.
  7. 8t7jimmy
    Mar 2, 2004
    137
    Is'nt their another locking ring in the middle of the hub like the drawing above?
