14 bolt hub removal (updated)
Discussion in 'The Garage' started by chulisohombre, Sep 17, 2002.
  1. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i got a 14 bolt from the junkyard.im going to install it next week.i tried to get the hubs off today and i think the brake pads are rust locked onto the hubs.i tried apraying some penetrating oil on them and am going to try again in a couple of days.anybody have any good ideas on how i can get this think apart.this is the first 14 bolt ive owned and hopefully the last,but i need to get it apart so i can see what everything looks like.also,does the 80-90 weght lube the bearings or is there supposed to be bearing grease on the outer bearings?
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Re: 14 bolt hub removeal
    Have you tried backing off the brake shoes using the star wheel from the back side? I did this on one awhile back, and it worked well. And I used the BFH, always a handy tool. /forums/images/icons/grin.gif
  3. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i got the hub to move but the brakes are rusted to the drum and the springs and everytrhing else do not move either because of rust.im going to get the disk brake kit so i dont need the drums but i cant get them off of the axle.i also tried the adjuster but too much rust for that to move also. /forums/images/icons/frown.gif
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Rear axle is completely lubed by gear oil ONLY. Just make sure that when you fill the pumpkin for the first time, you tilt it little bit toward each wheel to make sure the oil gets into the bearings, then top off the pumpkin and call it good.
    No idear on getting those drums off....mine were already disassembled when I got mine, and there's no road-salt here in CA....so things come apart easier anyway. /forums/images/icons/wink.gif
  5. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    thanxs greg.one problem solved,now for the other.any better ideas than beating the hell out of it with a sledgehammer.i was just using a 16 ounce ballpeen hammer before.maybe a sledge will get it off /forums/images/icons/laugh.gif
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Just to ask the "dumb" question.....you have already removed the axles from the hubs, and removed the spindle nuts and washers, right? /forums/images/icons/shocked.gif
    If I am imagining it right, the drum you are trying to remove it pressed to the outer hub using the 8 wheel studs, so it's going to come off as a complete assembly.....then, once you have the drub/hub off, you can press out the wheel studs to allow you to seperate the drum from the outer hub.
    Sorry if that's obvious....I'd hate to see you banging on that drum all day, and never get anywhere! /forums/images/icons/grin.gif
  7. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    yep all is torn apartits just that the drum is rusted to the brake pads and it wont come loose.i already broke the brake retainers that hold it to the backing plate so the brake are free themselves but the springs are still holding onto the brakes.i wish gm hadnt gone with this kind of a setup.should have been two piece like the 12 bolt.would have made my life much easier.but once i get it off i wont have to worry bout it again,but thats my worry still right now.getting it off of there.
  8. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    To add to the "obvious", is the parking/emergency brake lever pushed down (or even if the pedal is up where it should be, the cable sometimes hangs up). And if it is a free standing axle, check the individual cables that attach to the backing plate to make sure they aren't stuck in a position where they are pulling.
  9. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    BFH, and can you fit a long prybar between the backing plate and the lip of the drum? Leverage sometimes is more effective than violent abuse...even though the abuse is more fun. /forums/images/icons/grin.gif
  10. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    got torches?? I had one that wouldn't budge no matter what I did. I finally got pissed at took the torches to the drum and cut it off!! I was putting disc on it so I didn't care about the drums. Maybe a 20# sledge and some anger will crack it!!??
  11. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i had this same problem and ended up buyin a whole new 14bff and used the drums off of that. but to get the old ones off, i used an 8 foot pry bar. worked really nicely. just dont screw up the threads or else u will need a thread file. or, if u want somethin other than torchin em off, use a big sledge hammer and shatter the drums. hit right around where the "fins" are on the outside. good luck
    NITRO
  12. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    MAN!!!!! I wish I had seen this earlier!!!!!!!!
    I had this same exact problem and the way to get the thing off without braking anything is quite simple, just too easy!!!!! First, take your little hammer and tap, tap the lugs, therefor sending them into the brakes themselves!!!! Once all the lugs are out and sitting in your hub, take the hub off! Then take a long extention and a socket and undo the four bolts that hold the backing plate onto the axle!!!! It's easy and a whole lot less stressfull!!!! Then all you have to do is fish the lugs out of the drums and you're finished!!!! Let us know how it turns out!
  13. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    batmanjr looks like thats is the best idea ive seen so far.ill try it on sunday(my next day off again)and ill let you guys know how it works.thanx for all the help!!
  14. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    o, i also used a huge ass wheel puller. i just machined a piece of metal to fit in the axle tube a lil bit, and tightened it up. between that and the 8foot bar and the lil pry bars, it all came off easily, just kinda messed up the brakes
    NITRO
  15. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    swanson you are the big winner today.the prybar idea worked.went down to ace hardware and got me a 3 footer(biggest they had)and pryed the hell out of it after i got a chisle in between te hub and backing plate.took about 2 hours of going back and forth side to side but finally got it.thanx for all the help guys,i knew we could do it.haha
