14 bolt hubs the same on 2.5 - 3.5 drums?
Discussion in 'The Garage' started by Cola-man, Jan 19, 2005.
  1. Cola-man
    Cola-man Registered Member
    Jan 8, 2005
    6
    Montgomery, AL
    I'm searching for a set of hubs for a Corporate 14 bolt FF out of a CUCV. These had 3-1/2 inch brakes and I was wondering if I could use the hubs from an axle with 2-1/2 inch drums? I've found a set of 3.5 drums just need the hubs. Will this work or am I totally off couse here?
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    AFAIK the hubs are the same for both brakes. At least i have helped someone do a disc conversion that had the 2.5" brakes and it came out good so i'm guessing they're the same. The only hubs that i would bet are different are the ones that have the outboard mounted drum that removes without having to remove the hub assembly.
  3. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    Hubs are the same. The difference is made up in the backing plate. The 3.5" backing plates are offset inboard further than the 2.5" units are.
  4. Cola-man
    Jan 8, 2005
    6
    Montgomery, AL
    That's what I hoped but wanted to check here before I forked out the money. Thanks for the help.:grin:
