14 Bolt indenty
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazin72, Nov 24, 2000.
  1. blazin72
    blazin72 1/2 ton status
    Oct 24, 2000
    279
    Oklahoma
    I know I have ask about 14 bolts before but I have another ?
    I believe I found a full floater but how do you tell if its a dually or single rear end. Its already out on the ground and I dont know what it came out of. I took the cover off and the ring gear is 41 and the pion is 11. Is this a 3.73?
    The real ? is how do you tell by the drums if it was a dually or not.
    Thanks for all the help.
    I found it cheap and I didnt want to pass it up.
    Blazin 72
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Open up the calculator on your computer and divide the ring gear teeth by the pinion gear teeth. 41 / 11 = 3.7272 also know as 3.73
    Sorry I don't know what the duel rear wheel 14B looks like - the drums are so massive on my single-wheel 14B that I would have thought it was a duellie but it still had one wheel on it when I got it, so I knew it was a single.
    -- Mike
