14 Bolt installation
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pomai, Mar 10, 2002.
  1. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    This is my first time. So please bare with me. If there is anything that I have not filled out, or done properly please let me know. I've been trying for a long time to figure out how to post a question. So here it goes, I have a 88 chevy full size blazer. I'm planing on installing a 14 bolt full float rear end from a 1 ton, so I know I have to move the perches, any ideas on how to remove the curent perches, and were to get new ones from.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If you get a 14ff from a 3/4 ton you do not need to move spring perches. The 1 ton 14ff's are a direct bolt in for the 69-72 blazers and the 3/4 ton are a direct bolt in for the 73-91 blazers. You may need to play with shocks mounts depending on what your pinion angle needs to be. You will also need a conversion joint for the rear. I believe everyone has said it is a napa #447
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    If you do end up having to move them... just cut them off and have the welded back on in the right spot... what I will be doing someday with the 14b sf I have...
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Yup you will have the move the perches if it is a one tone rear. You can make your own perches like this http://www.off-road.com/chevy/tech/perch
    Also unless you have a nice plazma cutter or have no lief and a while to cut them off with a sawzall you should hack them off with a die grinder pretty quick and pick up some new ones. A lot of the street rods guys and I have used some dodge perches. They are a little wider then the original perches, but they will work mint. Your local Dodge dealer has them in stock. I have the part number somewhere in the garage. If you need it I can track it down for ya.
  5. bmwsma
    bmwsma Registered Member
    Nov 17, 2001
    67
    Chalfont, Pa
    So what's the difference between a 3/4 ton and a 1ton 14 bolt? Are the axle splines different, yoke etc... I have a 1ton 14 bolt sitting on my garage floor out of a 75 GMC pick-up waiting to go in. I measured the distance between the perches and could sware the are equal to that of my 88 blazer. Are they off by a lot? Maybe my measurement looked close?!
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The only difference between the two are the spacing of the perches. If memory serves me right, spacing on the 3/4 ton and blazer are 42 1/2" centers on the perches. I don't know exactly what the 1 ton is but it is narrower. I think it is around 40 1/2"
