14 bolt is finally installed with issues...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bottomfeeder, Sep 22, 2004.
  1. bottomfeeder
    bottomfeeder 1/2 ton status
    Mar 9, 2004
    277
    Oklahoma City
    14 boltff is installed on the Blazer. It has a detriot locker and 4.56 gears. Got a Lock rite Locker and 4.56 gears installed up front in the Dana44. Come to find out, it's not a Dana44, it's a 10bolt. 1977 Blazer should be a d44 right? Probably swapped it out at some point. Anyway, angle on the drive shaft is too sharp. Drive shaft is also too short. I am lowering the transfer case to help correct this. Front drivers side spindle had a seized bearing. Not much damage was able to fix. Same drivers side Warn hub won't engage. I now need some hubs. /forums/images/graemlins/frown.gif Hopefully I will be able to drive this thing today. I am now officially broke!! Anbody have any hubs they want to sell for cheap?
    /forums/images/graemlins/mad.gif /forums/images/graemlins/frown.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you need a hub to run for a little while I have my second spare hub you can borrow. It is a Warn Premium. It is just sitting in my toolbox at my house. If you need to borrow it till you can get some $ for a set of hubs let me know.
    Glad to hear your swap is done. /forums/images/graemlins/thumb.gif You can always add a shim in your leaf spring pack to help rotate the pinion upward also.
    Harley
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Lowering the transfer case is a bad idea. Leave it alone.
  4. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    Why do you say this?
  5. bottomfeeder
    Mar 9, 2004
    277
    Oklahoma City
    It's too late for that. Why is it a bad idea?
    What hubs should I get for this front end? Anybody have any does or don'ts?
  6. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I lowered mine 2 yrs ago, no issues that I know of.
  7. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    It's 6 of one and a half dozen of the other. If you lower the t-case you rotate the cv upwards causing more bind. However at the same time you are lowering amount of angle the drive shaft has to operate at. You should check for bind at the cv's before using 4wd, if you find any you can grind the stops built into the cv and that will allow you a little more angularity.
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Warn Premiums. That is what I run and I love them. Mile Markers are good too. They have the same warranty Warn does, you break them we replace them.
    Harley
  9. bottomfeeder
    Mar 9, 2004
    277
    Oklahoma City
    Do you work at an establishment where I can aquire some of these items at a reasonalble price? If not, then where should I obtain me some new hubs?
    Thanx
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    No, I don't. You might try Desert Rat. That is where I got mine. They had the cheapest price in town when I bought mine.
    Harley
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I have had my t-case stock, lowered, stock, then lowered again (as lift type/travel) progressed . No problems yet. I did manage to rip a bolt through the frame last time out but that is an issue with the leverage from the spacers I have since addressed.
    As for hubs, warns. Most Desert Dorks will honor the warranty no matter what (even though it is stated strait out that rust and/or axle failure voids the warranty). You are lucky eric's desert rat in mesa is a pretty reputable place from everthing I have heard. The ones up hear in phoenix are a big friggin' joke. I refuse to do business with them any more (but that story will be saved for the camp fire).
  12. bottomfeeder
    Mar 9, 2004
    277
    Oklahoma City
    What about the place on Washington in Phoenix? Anybody have anything good to dsay about them?
  13. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    4 Wheelers Supply is a good shop but they are proud of there stuff. I called them and they wanted $15-20 more then Desert Ratfor the same set of Warn Premiums.
    You can always tell them (4 wheeler supply) you are a member of Arizona Virtual Jeep Club and get 10% off. They usually dont check, as long as you mention the name they give you 10% off.
    Harley
  14. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    so does that mean that yer loc-rite didnt work because it was for a D44 and not a 10bolt??
    cuz if so I have a new loc-rite for a 10bolt I'd trade straight up for a D44 loc-rite /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  15. bottomfeeder
    Mar 9, 2004
    277
    Oklahoma City
    No, I got the right locker. We just thought it was a D44. The right locker was purchased after this fact was discovered. Everything works pretty good except the driverside hub.
