14 bolt is torqueing up when put in gear
Discussion in 'The Garage' started by mo, Dec 21, 2005.
  1. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    When I put my truck in gear, or accelerate from a stop, the axle is torqueing up and then clunking back down. I think it is the whole axle, maybe just the pinion, u bolts are tight, all the nuts are tight... Think the pinion bearings are toasted? My truck is retired for the winter, so I can take it apart once I have time, but curious of whats going on. The pinion angle is pretty high, maybe starved the bearings?
    thanks
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Sounds like a bad case of axle wrap.
  3. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    mine did a weird oise a few times before in because clear what killed it,
    pull the cover, check for metal from the bearings and see if the carrier bolts have backed off, after talking about mine doing it I have heard about it happening to plenty of people
  4. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    just started doing it on the way home from beating on it over the weekend, looks pretty nasty though when it does it and sounds awful too. I cant imagine the ujoint or something else in there will last too much longer as is
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Pull the driveshaft and lube the slip splines really well. Put it back in and see if the clunk is gone. A binding slip joint is the most common cause of the clunk. (The pinion angle will always change when power is applied. You don't usually notice it, but if the driveshaft is binding then you'll hear and feel it!)
  6. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    I second the axle wrap. Mine used to wrap alot before I made a traction bar.
  7. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    I'll lube the shaft:D , and see if that helps, if it is axle wrap, why would it just start all of the sudden, I would think it would have been there from the begining?
    Maybe i can get a video of it, i"ll try tonight...
    thx
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    check your leaf springs. my 82 C10 had something similar going on, ended up that the upper part of the spring eye was missing. the bolt and the bushing were still there, and good, just the leaf spring was just sitting under them. raised the truck up on a lift and when the suspension dropped out, it literally dropped out. also my 86 C10 and my 73 C20 had broken springs at the center pin that caused some funny stuff for me.
  9. diesel4me
    Jul 24, 2003
    17,540
    927
    Massachussetts
    same thing happened to me!
    My 81 G10 van's rear spring eye on the front of the drivers spring side did exactly that too!:eek1: ..one day I pick it up to change a tire, on my friends lift,and I see the leaf spring lower itself away from the bolt and bushing!..snapped the eye off about halfway around!..:eek: ..
    I had been hearing a loud thud and clunking sound during a 2500 mile trip to TN a few months before,and I put in a new tranny mount when I saw the old one was oil soaked and separated--thought that cured it,but once in a while I'd still year that noise--and it seemed to wander around a lot,despite having a nice tight front end and steering parts!..now I saw why!:doah: ..
    I was about broke as usual,couldn't afford even a used junkyard spring for it!..so I wrapped a peice of 3/16" thick flat stock the same width of the spring around the eye,and about 3" past it,and clamped it in place with heavy 1/2" square U bolts as a "temporary fix"..that was in 1999..:whistle: ..
    I took it off the road in Dec. 2003,and it still needs to be fixed right..:tongue1: ..
