14 bolt lug pattern
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by XJOSHX, Mar 3, 2003.
  1. XJOSHX
    XJOSHX Registered Member
    Mar 3, 2003
    50
    New Bedford Mass
    I am planning on doing a 14 bolt rear axle and a 10 bolt front for my blazer. My question is, is there any way to get the same bolt pattern on the front and rear so I don't need to buy different rims when the time comes? I don't care which pattern it is as long as they are the same.
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    A FF14 will have 8 0n 6 1/2 bolt pattern. You can upgrade to 3/4 ton hardware on the front which will have the same 8 lug pattern. There is also a more costly and less desireable way to convert the rear to semi-floating with 6 0n 5 1/2 like you probably have now.
  3. XJOSHX
    Mar 3, 2003
    50
    New Bedford Mass
    yes, I am figuring it to be a better idea to convert the front. what parts would I ened to do the conversion?
  4. XJOSHX
    Mar 3, 2003
    50
    New Bedford Mass
    ok I guess I should have searched this site a little better than i did. Sorry about this post guys, it's right in the tech section
