14 bolt mini spool?
Discussion in 'The Garage' started by fordslayer383, Feb 28, 2005.
    i seen in the reider racing add for a 14 bolt mini spool. it was cheaper that a detroit- whats the deal with these? anyone run one
  1. metto
    metto Registered Member
    Jan 17, 2005
    64
    Raleigh, NC
    basically just a full spool that replaces your spiders instead of the whole carrier. some people run them in street/trail trucks and pull them in the winter so they can have open diffs for snow but be spooled in the regular weather. fits in just like a lunchbox locker but its a spool all the time
  2. you mean totally locked all the time?
  3. metto
    Jan 17, 2005
    64
    Raleigh, NC
    yep they are 100% locked whenever you have it installed in the diff. some have said that they are weaker than a full-carrier locker or spool, and while this is true, there shouldnt be any stregnth problems with an application like a 14ff
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    If you go over to POR, there is a vendor selling the Sandy Cone 14FF mini spools for aroudn $189+shipping. Haven't seen anyone vendors on here sell them yet. Also, Yukon makes a full spool which is a little over $200.
  5. detroit lockers are pretty cheap for a 14 bolt anyway!compared to other lockers for other diffs plus id just weld up tha spiders instead (of gettin a mini spool)
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, you can get them around $355 shipped.
    Just depends on what type of locking action you want and how much you want to spend.
    Mini spool - $190
    Full Spool - $220
    Detroit - $355
    T-Locker - $? (not fond of the cover mounted actuator)
    ARB(soon) -$900?
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    think the ARB is expected to top $1000.
  8. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    its pointless in my opinion to get a mini spool when a full spool is 30 dollars more and install is pretty much the same
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Why pay for a mini-spool when you can just have it welded. It is the same thing. Sure a mini-spool may technically be stronger but I have not heard of anyone breaking a good weld job in a 14bff.
    I run a welded 14 bff in my semi-DD trail truck. Its not that bad on the street, the only part that really sucks is the tire wear.
    Harley
  10. metto
    Jan 17, 2005
    64
    Raleigh, NC
    people run a mini spool so they still have the option of putting the spiders back in in the winter so they dont have the truck pushing its self all over the road in snow and ice. also with a mini spool or lunchbox you dont have to deal with gear setup.
  11. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    You can weld a 14bff up like a minispool design. It is the same process to drop the minispool as the welded and stick in a set of spider gears. People who swap in Detroits practically give there old spiders away so that is not an issue.
    A welded rear is not that bad in snow or ice. I ran my welded rear in Colorado for a winter with no problems. It is about learning to drive that setup.
    Harley
  12. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
