14 Bolt or not??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by militaryblazer, Dec 14, 2000.
  1. militaryblazer
    militaryblazer 1/2 ton status
    Nov 14, 2000
    235
    Azle, Tx
    I found a truck for sale near me. It is an '84 body on a '73 3/4 Ton Frame. It has the 8 lug axles but what are they. I was wondering if it has the 14 bolt in back and what would the front one be. I want the truck for the axles and the winch bumper on front. Is $500 a good deal??
    <font color=orange>'86 Military Blazer with 4" Lift & 33" Tires</font color=orange>[​IMG]
  2. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    It should be a 14 bolt and a dana 44 front and i think $500 is pretty good you should have some extra parts off of the truck to sell also.
    [​IMG] SMP
  3. militaryblazer
    Nov 14, 2000
    235
    Azle, Tx
    Also in my area is a blazer with a 468 BB, and most of the other engine goodies on it, 33" swampers, 4" lift, and the 10 bolts axles, with a really beat to pieces body on it for $4000. Does that sound like alot?
  4. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    a 468 454 is already .060 over, thats like the limit for a street 454, especially a 2 bolt. If the bodies beat the drivetrain is probably also. check it out real carefully. Cash talks, if you really want it set a price for yourself, offer it, and if he dosen't take it walk away......js
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Yes, it should have a full floater 14 bolt rear and a Dana 44 front.....just keep in mind that if the body has been changed then there's a good chance all of the drivetrain might not be original either. $500 probably isn't a bad deal if it's at least mostly complete and has other salvageable parts on it.
    I also agree with the other post on the Blazer. If the body is beat up then the drivetrain is probably beat up also. Also, is somebody put a built big block in a beat up truck with stock 10-bolts, I would start to question whether or not the engine was really built right or just cobbled together.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You could do what I did. Buy the truck. Put the 3/4-ton axles under your Blazer. Put the Blazer axles under the truck. You'll need a crossover type U-joint to mate the driveshaft to the axle. Sell the truck. [​IMG] Also swap the bumpers between the two since you want the winch bumper.
    Make sure the axles on the truck are a decent gear ratio or you'll be dumping lots of money into swapping gears. Most of the 3/4-tons of that era came with 4.10's or 4.56's which is fine. An open rear diff is also the most desirable since you can literally drop in a Detroit Locker for $300. If it has the facotry Gov-Lock then you have to spend more money to upgrade.
    http://ThunderTruck.ColoradoK5.com
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Count the bolts on the rear cover. 14 bolts........14 bolt. I'd go for the $500 truck and do what Harry did, great way to upgrade. Sometimes you can even make a buck or two on the deal.........
    <font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;http://www.blazzinor.coloradok5.com
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    that is just what i am looking 4 wish i could find one in my area. i would do it!!!!
    s.smith 77blazer lookin 4 mud
  9. Grim-Reaper
    7,385
    Atlanta
    Yeah should be a 14 rear and a D44 front but it my have the old style D44 that is less desirable. The old style had external hubs. The externals are hard to find. If it has the internals it would have the same style that your truck does. It may also have smaller U-Joints than the newer trucks with a D44. Many people don't know that there was a U-Joint change in the early 70's. There should be a sticker either inside the glove box door or on the top of the driverside inner fender. It will be While with a Blue header and blcak printing. This will list what options the truck has. Hopefully it's still there and readable. The stock gear for a 3/4 is 3.73. It will say if it has 4.10's The exception is if it is a I6. those all got 4.10's. It will also list if it has a locker.
    Like one of the other guys pointed out swap your axles under it and resell it. You may beak even like the other guy said. Swapping to the newer style hubs is not big deal just need to get the Spindle and hub. Make sure the brake backing plate and caliper are the same.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  10. BurbinOR
    5,829
    Oregon
    Shannon, might have a line on a couple of 14 bolts - let you know in a couple of days.
  11. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    that would be cool. thanks frank
  12. militaryblazer
    Nov 14, 2000
    235
    Azle, Tx
    I think I read somewhere that even if the axle has 14 bolts that it isn't always a 14 bolt? I think I saw that in Petersons.
  13. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    14 is the number of bolts on the ring gear and its usually the number on the cover. If it has 14 bolts and its got a pointed bottom on the cover then its a 14 bolt FF.
    90K5
  14. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    14 bolts have 14 cover bolts. The ring gear is held with 12 bolts, trust me I just had mine apart to weld the spiders.[​IMG]
    Rene
