14 bolt out of an early 80's 3/4 pickup, will it bolt to my 91 k5???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CiceroK5, Jan 15, 2003.
  1. CiceroK5
    CiceroK5 Registered Member
    Jan 14, 2003
    41
    Lake Bluff, Il
    14 bolt out of an early 80\'s 3/4 pickup, will it bolt to my 91 k5???
    To anyone that has swapped ina 14 for a 10 bolt what is involved besides the basics?? ANy input would help!!
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Re: 14 bolt out of an early 80\'s 3/4 pickup, will it bolt to my 91 k5???
    will bolt right in.. may need the conversion u-joint...
    you'll need new u-bolts and nuts...
    brakes are the same...
    the e-brake should work too... /forums/images/graemlins/thumb.gif
  3. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    put an 80 under my 91 sub. no issues at all. used 80 brakes (went thru them 1st), swapped lines over.. new u-joint & U-bolts and Poof! Done! (did front a bit later).. and of course a set of 8 lug rims/tires.
    /forums/images/graemlins/blush.gif oops! forgot about the parking brake part! I just figured that was 'optional equipment'! but have learned otherwise!
  4. AZ_Overdrive
    AZ_Overdrive 1/2 ton status
    Dec 18, 2002
    117
    Arizona
    I just completed this exact swap back in November. 1980 3/4T 14 bolt into my 89 Burb. The E-Brake hookups don't match. The burb backing plates utilize a small hole for the cables to "snap" into but the 14 bolt uses a 2 piece bracket thing that sandwitches the cable as it passes into the backing plate. I still don't have my E-brake hooked up.
    Everything else is strait forward ( 3/4 T Ubolts and conversion Ujoint).
    Hope that helps.
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I've heard that a 14 bolt from 85-later will have the proper e-brake cables. You may want to get one of those, if you want/need a working e-brake. I will be.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    will 85-up FF cables swap to 84-down FF ?
  7. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    after discovering the e-brake cables on my 78 14boltff did not want to play with the setup on my 91 I looked in the shop manual for the 78 to see how it was done "back in the day". It is a fairly simple system to copy. all you will need is a little angle, some cable, a few eye hooks and cable connectors. I should have taken pictures but at the time all my wheeling buddies drove Heeps and could not care about real trucks. Now its just too f'ing cold to spend time under the beast, but if your clever it is very simple to "invent" your own solution.
  8. PineyPower
    PineyPower Registered Member
    Jan 16, 2001
    52
    New Jeresy out in the pine barrens
    Why did u guys change ur U-Bolts?? When i put mt 14 bolt in i didn`t change them and everything work out good..
  9. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    Ive recently accuired a 14bff out of a 79sub. After a disc brake conversion and a paint job it will bolt up nicely to my '87 k5. Who makes a good conversion U-joint?
    Jason
    305/700r4/208/35s
  10. K5on38s
    K5on38s Registered Member
    Dec 11, 2002
    90
    Buffalo, NY
    Measure the distance between the spring purches. Mine where different. Also, make sure the shoke mounts are in the right locations. Mine where switched. youll also need the adapted ujoint (about 30$) and If your running 15" tires and intend on staying w/ them and not goin to 16" make sure you order your rims, or adapters ahead of time. I was neglegent and soon found out that gettin 15" 8 lug rims is like pullin teeth, seein as most are a specail order item and take a few weeks to get /forums/images/graemlins/deal.gif aslo... remeber your pinion angle is gonna change because the pinion nose on a 14bolt is longer than a 10bolt...it wont change much but if your's is bad to start with itll get worse..(i just did this swap about a week ago so if you need anything just send me an email /forums/images/graemlins/grin.gif
  11. K5on38s
    Dec 11, 2002
    90
    Buffalo, NY
    10bolt axle tubes have a smaller diameter than a 14 bolt
  12. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Anyone know the part number for the 1310-1350 conversion u-joint, just did 12/14ff swap and want to drive it!! thanks.
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    so 73-up blazer are 42.5"; spring pack centers ?
  14. heavy4x4
    Aug 28, 2002
    3,270
    You must have had to stretch the u-bolts into a new shape /forums/images/graemlins/shocked.gif, because the 10 bolt axle tube is 3" in diameter, whereas the 14 bolt is 3 3/8"
  15. heavy4x4
    Aug 28, 2002
    3,270
    Napa #348 if you went from a 12 bolt to a 14.
    Napa #447 if you went from a 10 bolt to a 14
  16. heavy4x4
    Aug 28, 2002
    3,270
    Yes, 1/2 and 3/4 ton second gen's have a 42.5" spring perch center to center measurement.
    1 tons are 40.5"
  17. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i ask cuz first gen k5 and 1 ton and 3/4 longhorn are 40" centers unlike rest of models(42.5")
    thanks
