14 bolt parts & 8 lug 10 bolt outters
Discussion in 'Parts & Trucks Wanted' started by K5Chris, May 11, 2004.
  1. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    finally got me a 14bFF... this is what i need:
    open carrier
    detroit
    4.56 r&p
    master overhaul kit
    1410 yoke
    spring plates
    U-bolts for 3.5"-4" block
    1" zero rates or 3.5"-4" blocks
    shock mounts
    and... maybe disc brakes if the price is right
    also need 3/4 ton 8-lug 10 bolt/D44 stuff:
    hubs, rotors, & caliper mounting plates
    *must be from '77+ axle
    could also use some 15x10 8-lug wheels
    if you got any of this, or know where i can get the new gears, overhaul kit, & detroit cheap.... let me know..
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    hubs/rotors
    spindles
    calipers/caliper mounting plates
    You can use your existing spindles and calipers with the 1977-87 D44/10 bolt 3/4 ton hubs, rotors and backing plates.
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I'm going to pickup a 14bolt that has 4.56's in it but I'm going to 5.13's. SO I will have 4.56 and the spacer to get them ona 4.10-down carrier on Ebay hopefully first of next week. how big of a hurry are you in for them? /forums/images/graemlins/thinking.gif
  4. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    no hurry at all. i cant afford everything yet, so i'll piece it together til it's done. let me know when your ready to unload, maybe we can work something out.
  5. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    oh really? cool. i had heard that the 3/4 ton spindles/bearings were bigger.... guess that means less for me to buy, cool /forums/images/graemlins/woot.gif
  6. kennyw
    Jun 9, 2002
    13,224
    94
    Spindles and bearings are the same as long as you stick with parts from the same generation. 71-76 are the small bearings and 77-87(91) are the large bearings.
  7. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    cool, thanks /forums/images/graemlins/waytogo.gif
    i guess i got my $24.95 worth of info out of this thread alone. /forums/images/graemlins/woot.gif
  8. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    to the tiggetytisop
    think i'm getting hooked up with some spring plates...
    open carrier and detroit may have to wait.
    i do NEED disc brakes now. drums are toast.
    prolly just stick with 1350 joint too instead of 1410.
    i could use an Angle Grinder, if someone's got one in decent shape that works good. /forums/images/graemlins/grind.gif
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I've got some D44 calipers for your rear disk conversion if your interested pm me /forums/images/graemlins/thumb.gif
