14 bolt pinion carrier install** prob solved, thanks
Discussion in 'The Garage' started by desertrat67, Apr 18, 2007.
  1. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    OK, which way does the pinion carrier go? There are two oiling ports in the carrier, one a 1/2 in hole and the other a large ununiform shape. Does the larger opening go to the top for the oil to enter to lube the bearings, or is it the other way?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    I thought the bolt pattern was setup so it could only go in one way
  3. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    hm, i'll have to check that.
  4. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    i feel retarded now. it is large openning up by the way.
  5. 1977k5
    May 26, 2003
    9,991
    130
    So does that mean I was right?
  6. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    yes, one way install. thanks.
