14 Bolt question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85Blazer, Jul 14, 2004.
  1. 85Blazer
    85Blazer Registered Member
    Feb 25, 2000
    30
    Dunkirk, MD
    I need to replace my worn out 1979 14 bolt rear. Will a rear from a 1997 1 ton fit with minor mods? If not what is the latest year I should look for?
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Not sure if the mods are minor. I don't believe you can run 15's on the new rears look for an 87 or older, or just rebuild the one you have /forums/images/graemlins/waytogo.gif
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Careful, disks or drums? ABS or not? There will probably be some spring perch cutting/welding needed. I don't know for sure though.
    next->
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Its drum, no abs in the rear, it will work, youll have to move the perches inward, move the shock mounts, and take off the bumpstop pads.
