14 bolt question
Discussion in 'The Garage' started by socal chevy, May 2, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    I know this has been discussed, but hey thats what forums are for right?? :D
    Im going to be installing my 14bff soon, and just found out that the 14bff is 3" narrower than my 10b thats in my truck right now... Is that true? How can I correct this? what are my options? Can I get different backspacing on the rear wheels? Are spacers safe?...Thanks!! :confused: :cool1:
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    all GM rear axles(SRW) are that way. Your 10 bolt rear is that way, you just didn't notice. 1.5" spacers on each side are the best fix. You could get different rim backspacings but thats stupid IMO.
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Isn't he refering to the spring perch placement on the 14b?
  4. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Why are different backspacings stupid? Just wondering if I missed something. I've been running 2.5 inch backspacing for a long time, with no probs. Just trying to find out if you know something I need to know too.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Stupid because you can't rotate tires. Detrimental to the axles? no. Just my opinion of it. Many thing spacers are a waste. I'd just run spacers on a street machine, or something I wanted to look good.
    I thought he was saying his 14bolt is narrower than his FRONT 10 bolt. 14 bolt and rear 10 bolt are the same width. Both are 3" narrower than the front axle.
  6. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Exactly. If he got a 1 ton 14b the spring perches have to be moved out.
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I got confused myself here, ok.
    Yes.
    You can get spacers, or retube the axle to make it 1.5" wider on each end, also would need new axles. Or get a dooley 14b I belive.
    Yeah, but I agree with Sleddy, thats stupid
    Safe enough, how often do you hear of a spacer problem? Alot of the crap with dubs and such have spacers to fit them without rubbing.
  8. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    cool thanks guys!
  9. jekbrown
    May 19, 2001
    45,032
    366
    Vancouver, WA, USA
    I have had 1.5" spacers on my ff14b for years, no problems. Every single time I take my tires off I bust out the torque wrench to make sure they aren't getting loose... and every single time it just "click click"s at me. Spacers are a good way to even out the front and rear. I don't like having difference width axles, I want the rear to predictably track the same as the front. A shade more width is also a good thing from a stability standpoint.
    j
  10. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    go to scbd.org and pm tonyp he makes spacers!! :D
  11. camodk5
    camodk5 Newbie
    May 2, 2005
    4
    California
    All rear GM axles are that way I think. It looks fine and it works fine. Its only a inch and a half on either side. No big deal. Its the way its been. When you get it on you will see its awsome. Just my opinion.
