14 bolt question
Discussion in 'The Garage' started by onlychevy6, Mar 20, 2006.
Which 14 Bolt is better
  1. 73 - 85 14 bolt FF
    54.2%
  2. 86 to present 14 bolt FF
    29.2%
  3. Don't know Don't Care
    16.7%
  1. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    So which is the better 14 bolt? 73-85 or the 86 to present?
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    There's a major difference?
    As long is it's a FF 14, it don't matter, although, I think the older ones are still easier for the swap in...
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Id say the later style. It has bigger pinion bearings. Also 96 and newer has a different pinion seal, fot those who care. But in reality, they are both great!!!:waytogo: :waytogo:
  4. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Are you talking about the housing ribbing differences or just the pinion bearing support differences ?
    Tom
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    no nekked option???? come on!
    ive got a '76 14b and its fine for me. i just put in all new seals bearrings, and gears so its basically brand new
  6. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    Actually. I was reading some informationon the 14 bolt ff. I currently have 12 bolt with dana 44 6 lug.
    and the article was saying 73-85 14 bolt had smaller pinion support bearing and the drums are held to the hub with the wheel studs versus the 86 to present has a larger pinion and the drum could be pulled without having to remove the hub and axle shaft.
    I thought the FF design the axle shaft was seperate all together? And could be pulled without taking everything apart. kinda like a SF.
  7. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    Damn my bad...
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Petersons, right? I read the same thing, which is great by me as mine is an '86.
  9. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    The shaft on a full floating axle does come out seperate from the hub/drum combo but some 14FF have the drum that is on the outside of the hub ( as in slides over the wheel studs ) and can be removed without the hub being removed as well. The older style has the drum pinched between the wheel studs and the hubs so in order to get the drum off the hub needs to be removed also.
    I do not believe that 1986 is the cut off year for the drum being on the outside of the hub . I believe it was 1988 when the new body style came out and the old body style trucks still used the old drum method until 1991. So it is possible to have two of the same year 14FF with different drum retention it just depends on what it came out of .
    Or I should say it like this - All solid axle style trucks used the old drum retaining method and all newer independant style trucks use the slide on drums. This is accurate to the best of my knowledge but I could have left out some exception to tyhe rule ......
    HTH's Tom
  10. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    yup
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    :haha: no worries
  12. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    There is a cutoff year that makes the disc swap different. I don't know what year though.
  13. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    mine was out of a (85?) CUCV. it had a lightly different housing than i have ever seen. it had more material around that huge lip. i wasnt able to get as much ground clearance when i shaved it.
  14. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    The axle in my 89 is out of a 92 or 93, it has slip on drums. But the rear in my 97 has pressed on drums. I've seen some other 14ffs, and from what I noticed it depends on what rating the truck is. The 89 14ff rear was a 3/4 ton, while my 97 is a 2500HD so I guess you could say a 1 ton. Saw a truck in a yard that had a 454 4l80, 3/4 ton that has the pressed drums.
  15. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    yeah i read that to do the disc swap on the newer 14bltff required replacing somthing, where as on the older ones you didn't have to....but for the life of me i can't remember what it was
  16. b454rat
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    One reason is there is no room. There is just enought room to hold on to a wrench to bleed the brakes. Discs on these puts the caliper in a different location than the older ones....
  17. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Oop's ! I guess I should not have said that ALL newer style trucks have slide on rear drums. Learn something new everyday ........
    Tom
  18. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    could the '97 have been an AAM 11.5 instead of a GM 10.5?
  19. b454rat
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    No, it's a 14ff. The AAM's didn't come out till the later HDs.
  20. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    the best one for me was the 73-85 3/4 ton because it fits in my 3/4 ton truck and blazers with no probs. I have no idea what year mine is but it bolted in so i guess i never really payed attention. I wouldn't get one too old as the spindles could be hammered or the mileage could be high. I swapped my stock 14 bolt because the truck had 378,000 miles of construction miles on it, multiple helicoils in the hubs, hammered spindle on one side, needed brakes, and it was 3.73 so it all depends on the condition to me.
