14 Bolt Question?
Discussion in 'The Garage' started by firefighter184, Mar 24, 2006.
  1. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Might be a dumb question, but how common would a 14bolt with 4.56 gears be? Is it worth it to wait until I find one (because they ARE common) or should I just be happy to get one with 4.10 or 3.73 and pay $500 to re-gear?
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Supposedly they are common, but I havent found one yet. Maybe one of these days I'll havta go pull every damn 14 bolt cover till I find a set....
  3. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    They were widely used in military applications but not too often in civilian trucks. Also, why would you pay someone to regear that axle? They are easy to gear, just takes the right tools, and most can be had for cheap, if not, find someone that will let you borrow their stuff for a day or two. You can keep looking for them, but don't expect to find one too quick.
  4. sweetk30
    Nov 1, 2004
    25,551
    545
    horseheads , ny 14845
    just a fyi the thick gears are cheeper than the 456 up thins. if you are going to swap ratios. and i had 1 with 456 and from miltary truck.
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    CUCV's and work trucks had them. They are faily common - you may post up on PBB if yo don't find one here.
  6. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    yeah, mine was out of a cucv. it came with 4.56s and a detroit.
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    When I get them I usually sell a 14ff with 4.56 and a detroit for 500.00.
  8. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
  9. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    $500 to re-gear? No way! $300 is more like it...you can do it yourself, it doesn't take much.
  10. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    I priced the gears and install kit at about $300, plus a local shop will do the re-gear for $150.
